[Geoserver-devel] authorization header forwarding does not work for getLegendGraphic with external style
Dear all,
We are experiencing problems with the getLegendGraphic request when using an external style at a secure url.
To fetch the external style the authorization header must be forwarded. For the getMap request
it works nicely using the authorisation forwarding feature implemented in https://osgeo-org.atlassian.net/browse/GEOS-10501
We expected that other requests would also work but the authorization header forwarding appears to be only implemented for the getMap request.
In order to generate the correct legend it is important that this also works for the getLegendGraphic request.
We would like to fix this, is it ok to create an issue to fix this or were there other motives to not forward the header for these requests.
Steps to reproduce:
You will need a shapefile and an associated sld stored in a secured external location.
Build & start geoserver locally
login to localhost:8080/geoserver/web/ (admin, geoserver)
go to security → url checks and switch the checks off or create a proper regex for the external style server.
go to services → wms → Allowed Style URLs for Authorization headers forwarding → add the host of the external style server
create a store for instance using a shapefile
download shape file attached to this task
stores → new store> shapefile
layers → new layer → select [layer ]-> publish
store the layer
test the layer
send get requests with an authorization header
and perform following request:
does not work: http://localhost:8080/geoserver/test/wms?service=WMS&version=1.1.0&REQUEST=GetLegendGraphic&VERSION=1.3.0&FORMAT=image/png&WIDTH=20&HEIGHT=20&layer=test%3test&bbox=-179.99999999999997%2C-90.0%2C180.0%2C83.623596000000080&srs=EPSG%3A4326&styles=&format=image/png&SLD=[url_to_external_sld]
Best regards,
Jasper
Hey Jasper:
Many of us were at a code sprint when you sent this message. You are very welcome to work on the same enhancement for GetLegendGraphics (and GetFeatureInfo would need it also).
You could ask the author of GEOS-10501 if they had any reason for only fixing it one location; they may not of been aware of how the other end-points worked.
Thanks for participating in GeoServer development.
Jody Garnett
Best regards,
Jasper
Hum… the Jira ticket title starts with “GetMap: support auth headers forwarding”.
It’s clear from the first word that it’s limited to GetMap…
Jody Garnett
Best regards,
Jasper
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
