[Geoserver-devel] Avoiding inadvertent linking between sld files (GEOS-5545)
I’m writing to get some discussion and eventually consensus on how to best handle:
http://jira.codehaus.org/browse/GEOS-5545
Long story short, it is possible and relatively easy to get two styles backed by the same sld file, so editing one changes the other as well.
The current situation arises because the sld and xml files are separate, and at least initially, they have the same name, but on rename, only the xml file gets renamed.
Approaches coming to mind:
  • stop naming the sld file after the style name, use the uuid of the StyleInfo. Pro, no conflicts whatsoever are possible anymore, Cons, good luck finding the style you want on disk (you have to get the xml file first and see that the name is)
  • when creating a new style, check if the sld name is already busy, if so, append random numbers to the original name. Pros, still somewhat easy to locate the sld file without opening the xml one (at least up until the style is renamed)
  • have the sld file be named _.xml, and rename the sld when the style is renamed. Adding the styleid in the sld file name prevents conflicts with concurrent file manipulation, but it’s still pretty evident what style the sld file is associated to
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Fri, Jun 14, 2013 at 4:21 AM, Andrea Aime
<andrea.aime@anonymised.com>wrote:
I'm writing to get some discussion and eventually consensus on how to best
handle:
* stop naming the sld file after the style name, use the uuid of the
* when creating a new style, check if the sld name is already busy, if so,
style is renamed)
* have the sld file be named <stylename>_<styleid>.xml, and rename the sld
conflicts with concurrent file manipulation, but it's still pretty evident
Sorry, I meant to comment on this issue the other day. I would be fine with
either of 2 or 3 here. I guess i would lean toward 2 for readability
purposes but i imagine 3 is simpler to implement.
A twist on 3 would be to try and use a shortened version of the identifier,
sort of like abbreviated git commits ids. Maybe even some sort of hash
scheme similar to git id's to avoid soem of the strange characters from the
uuid. Just thinking out loud. No strong opinion except that I think (1)
makes it too difficult to deal with the sld files from the filesystem.
Opinions?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
