[Geoserver-devel] Backport bot is back
during the weekend I’ve set up again the backport bot, based on QGIS own fork of it.
It seems to be working, as usual:
  • Open a PR, label it with the “backport ” label
  • On PR merge, the bot will try to create a backport PR, and will comment on the original PR if it cannot (e.g., conflict)
    The QGIS folks have one more customization on the token being used by the bot (I’m guessing customization of the rights the bot runs with), that our configuration currently does not have. I’ve inquired about it on qgis-devel, will update when I get an answer from them.
Give it a try, if all works fine we can port the same configuration over to GeoTools and GeoWebCache as well.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Nice, thx Andrea!
Nuno Oliveira
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Technical Lead / Project Manager
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I noticed something odd about the backport bot, it is not running actions (QA checks):
[Backport 2.21.x] [GEOS-10487] Log4J custom logging XML configuration is case-insenstive
This branch has no conflicts with the base branch when rebasing
Rebase and merge can be performed automatically.
Trying things out:
  • Converting to draft, and then ready-for-review, does not trigger the QA actions
  • any other ideas?
Jody Garnett
On Mon, 6 Jun 2022 at 00:48, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Geoserver-devel mailing list
Oh,
nice find, I did not notice!
Looks like a personal access token is required:
https://github.com/peter-evans/create-pull-request/issues/48
I’ll see what I can do
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
