[Geoserver-devel] Backport GEOS-6603 on 2.6.x and 2.5.x
+1
Is it OFF by default as the manual page makes to understand http://docs.geoserver.org/latest/en/user/webadmin/server/JAI.html?
-Jukka Rahkonen-
Nicola Lagomarsini wrote:
since it’s a month that my pull request on the master branch for JIRA https://jira.codehaus.org/browse/GEOS-6603 has been merged, I’m asking if I can do a backport on the 2.6.x and 2.5.x branches.
This pull request adds a new button on the JAI settings page for disabling JAI native Warp acceleration (similar behavior of the JAI native Mosaic)
Thanks.
Nicola Lagomarsini.
Ing. Nicola Lagomarsini
Junior Software Engineer
Via Poggio alle Viti 1187
Hi Jukka,
yes, it is OFF by default.
Nicola Lagomarsini.
2014-09-18 12:39 GMT+02:00 Rahkonen Jukka (Tike) <jukka.rahkonen@anonymised.com>:
+1
-Jukka Rahkonen-
Thanks.
Nicola Lagomarsini.
Want excitement?
Manually upgrade your production database.
When you want reliability, choose Perforce
Perforce version control. Predictably reliable.
http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
And before the UI change, is it also off by default?
Kind regards,
Ben.
On 18/09/14 18:48, Nicola Lagomarsini wrote:
Hi Jukka,
Nicola Lagomarsini.
<jukka.rahkonen@anonymised.com <mailto:jukka.rahkonen@anonymised.com>>:
    +1____
    __ __
    http://docs.geoserver.org/latest/en/user/webadmin/server/JAI.html?____
    __ __
    -Jukka Rahkonen-____
    __ __
    Nicola Lagomarsini wrote:____
    __ __
    Hi all,____
    __ __
    since it's a month that my pull request on the master branch for
    JIRA https://jira.codehaus.org/browse/GEOS-6603 has been merged, I'm
    asking if I can do a backport on the 2.6.x and 2.5.x branches.____
    __ __
    native Mosaic)____
    __ __
    Thanks.____
    __ __
    Regards,____
    Nicola Lagomarsini.
    ____
    __ __
    -- ____
    ==____
    __ __
    Ing. Nicola Lagomarsini____
    Junior Software Engineer____
    __ __
    GeoSolutions S.A.S.____
    Via Poggio alle Viti 1187____
    55054 Massarosa (LU)____
    Italy____
    phone: +39 0584 962313 <tel:%2B39%200584%20962313>____
    fax: +39 0584 1660272 <tel:%2B39%200584%201660272>____
    __ __
    http://www.geo-solutions.it____
    http://twitter.com/geosolutions_it____
    __ __
    -------------------------------------------------------____
    *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*____
    Le informazioni contenute in questo messaggio di posta elettronica
    e/o nel/i file/s allegato/i sono da considerarsi strettamente
    riservate. Il loro utilizzo è consentito esclusivamente al
    destinatario del messaggio, per le finalità indicate nel messaggio
    stesso. Qualora riceviate questo messaggio senza esserne il
    destinatario, Vi preghiamo cortesemente di darcene notizia via
    e-mail e di procedere alla distruzione del messaggio stesso,
    cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
    divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo,
    od utilizzarlo per finalità diverse, costituisce comportamento
    contrario ai principi dettati dal D.Lgs. 196/2003.____
    ____
    The information in this message and/or attachments, is intended
    solely for the attention and use of the named addressee(s) and may
    be confidential or proprietary in nature or covered by the
    provisions of privacy act (Legislative Decree June, 30 2003, no.196
    - Italy's New Data Protection Code).Any use not in accord with its
    purpose, any disclosure, reproduction, copying, distribution, or
    either dissemination, either whole or partial, is strictly forbidden
    except previous formal approval of the named addressee(s). If you
    are not the intended recipient, please contact immediately the
    sender by telephone, fax or e-mail and delete the information in
    this message that has been received in error. The sender does not
    give any warranty or accept liability as the content, accuracy or
    completeness of sent messages and accepts no responsibility for
    changes made after they were sent or for other risks which arise as
    a result of e-mail transmission, viruses, etc.____
    Want excitement?
    <mailto:Geoserver-devel@lists.sourceforge.net>
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti,
copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
Protection Code).Any use not in accord with its purpose, any disclosure,
reproduction, copying, distribution, or either dissemination, either
whole or partial, is strictly forbidden except previous formal approval
of the named addressee(s). If you are not the intended recipient, please
contact immediately the sender by telephone, fax or e-mail and delete
the information in this message that has been received in error. The
sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility
for changes made after they were sent or for other risks which arise as
Want excitement?
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
Hi Ben,
this is not an urgent fix, I can wait until the 2.6.0 is released.
Nicola.
2014-09-19 4:04 GMT+02:00 Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>:
Kind regards,
Ben.
Hi Jukka,
Nicola Lagomarsini.
<jukka.rahkonen@anonymised.com mailto:[jukka.rahkonen@mmmtike.fi](mailto:jukka.rahkonen@anonymised.com.)>:
+1____
Hi all,____
native Mosaic)____
Thanks.____
Regards,____
Nicola Lagomarsini.
– ____
==____
Italy____
phone: +39 0584 962313 tel:%2B39%200584%20962313____
fax: +39 0584 1660272 tel:%2B39%200584%201660272____
AVVERTENZE AI SENSI DEL D.Lgs. 196/2003____
  • Italy’s New Data Protection Code).Any use not in accord with its
Want excitement?
Geoserver-devel@anonymised.comsourceforge.net
mailto:[Geoserver-devel@anonymised.comsourceforge.net](mailto:Geoserver-devel@anonymised.come.net)
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New Data
Want excitement?
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
