[Geoserver-devel] Backport GEOS-7071, Security Test Setup not compatible with IBM Java
Hi all
Is it ok to backport GEOS-7071 ?. I think a git cherry pick will do the job.
https://osgeo-org.atlassian.net/browse/GEOS-7071
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
On Tue, Jun 23, 2015 at 10:51 AM, Christian Mueller <
christian.mueller@anonymised.com> wrote:
Hi all
job.
I don't see why not, backport requests are necessary only to backport new
features,
or for large bugfixes that might undermine the stability of GeoServer due
to their
invasiveness.
This one is pretty isolated and only affects test code, no actual need to
ask imho,
but just in case, +1 :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea
Thanks for the reply, it is better to ask as to make a mistake :slight_smile:
Christian
On Tue, Jun 23, 2015 at 11:04 AM, Andrea Aime <andrea.aime@anonymised.com…1268…> wrote:
On Tue, Jun 23, 2015 at 10:51 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi all
I don’t see why not, backport requests are necessary only to backport new features,
or for large bugfixes that might undermine the stability of GeoServer due to their
invasiveness.
This one is pretty isolated and only affects test code, no actual need to ask imho,
Ing. Andrea Aime
@geowolf
Technical Lead
