[Geoserver-devel] Backport GEOS-9361 to 2.1.6.x
Hello ,
A backport of GEOS-9361 merged under PR https://github.com/geoserver/geoserver/pull/3814 is proposed. The improvements done in this PR have not reported any issues in a custom build.
Please let me know should I proceed with the backport to 2.16.x or otherwise.
regards,
Imran
I.R
+0 as I am an interested party.
As Imran pointed out we have been using this isolate change in a custom 2.16 build for a more than a month now…
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1 from me
Ian
Ian Turton
+0 as interested party, but believe it ticks all the boxes:
  • Been on master for more than a month
  • Been in production at a customer site for the same time
  • Change is small, should be transparent to those not using it
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1, the proposal mentioned the backport:
https://github.com/geoserver/geoserver/wiki/GSIP-181
Simone Giannecchini
@simogeo
Founder/Director
