[Geoserver-devel] Backport [GEOS-9561] Add rest parameter to update native bbox when harvesting or deleting granules from image mosaic
Dear all,
I’m writing to ask permission to backport the improvement “[GEOS-9561] Add rest parameter to update native bbox when harvesting or deleting granules from image mosaic”. It allows to trigger the bbox updating when harvesting granules into or deleting from an image mosaic store via the rest interface, by the addition of a boolean parameter.
A cooldown month has passed and no backward compatibility is foreseen since by default the boolean parameter is kept to false.
Here you can find the JIRA ticket https://osgeo-org.atlassian.net/browse/GEOS-9561
Best regards,
Marco Volpini
+1
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Wed, Jun 3, 2020 at 11:49 AM Marco Volpini
<marco.volpini@anonymised.com> wrote:
Dear all,
I'm writing to ask permission to backport the improvement "[GEOS-9561] Add rest parameter to update native bbox when harvesting or deleting granules from image mosaic". It allows to trigger the bbox updating when harvesting granules into or deleting from an image mosaic store via the rest interface, by the addition of a boolean parameter.
Best regards,
Marco Volpini
Geoserver-devel mailing list
Been a few days, no worries have been reported. I’m +0 too, moving on and merging the backports
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
