[Geoserver-devel] Backport of [GEOS-10716] Build simple feature types schema using column descriptions if available
I would like to do a backport of [GEOS-10716] Build simple feature types schema using column descriptions if available ( https://github.com/geoserver/geoserver/pull/6315 ) to 2.21. Note that I plan on waiting until 2.22.0 has gone from RC to final released beforehand.
All of the settings for this feature default to off (in this case only turning on the comment feature in Oracle) and will result in no impact to previous installations.
Joe Miller
+1
Thanks for waiting for 2.22.0 release
Jody Garnett
+1 here as well
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
