would you mind if we backport the editable attribute description work back to stable/maintenance before the usual one month cooldown period?
The new description field in AttributeTypeInfo is optional, so everything should keep working as usual on existing data directories.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
