[Geoserver-devel] Backporting GEOS-9324, contextual legends, to 2.16.x
I’d like to request permission to backport this pull request to stable (like, now, instead of waiting another 20 days):
https://github.com/geoserver/geoserver/pull/3739
The PR adds a GetLegendGraphic request parameter to filter out the rules that have no match in the current
bounding box. It’s an extension of the existing “rule match count” functionality that adds the number of features
matching each rule, but instead of adding the count, it removes the rules that have no match in the current BBOX.
As you can see from the PR, changes are minimal, most of the PR is tests and documentation updates, the
core of the functionality (actual counting) has been in core for a while now.
Worries? Objections?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
backport pull request ready here:
https://github.com/geoserver/geoserver/pull/3812
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+0
Simone Giannecchini.
GeoSolutions Director
  • sent from my mobile, apologies for brevity and typos-
Well, no complains, 11 days since I’ve sent the first mail, and a week after the PR… guess nobody
is particularly concerned with it :smiley:
Merging
Thanks Andrea, I am looking forward to the change (it is a common request/confusion).
Jody Garnett
Hi Jody,
you can already try it out on both master and 2.16.x, let me know how you like it :smiley:
