I would like to backport GEOS-9327 on 2.16.x (tomorrow, a month will be elapsed since its commit on master).
https://github.com/geoserver/geoserver/pull/3758
The PR improve ncWMS getTimeSeries capabilities by supporting time list and time interval with period, adding a new query method to WMS utility classes.
Most part of the changes are in the ncWMS community module whilst WMS class has been updated with the add of a new method to query coverage’s times using nearest match.
If there isn’t any objection, I would backport that tomorrow.
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
