[Geoserver-devel] Backporting GEOS-9330 (ncWMS getTimeSeries noData exclusion) to 2.16.x
I would like to backport GEOS-9330 on 2.16.x (tomorrow, a month will be elapsed since its commit on master).
The update improves ncWMS getTimeSeries by excluding noData values from charts, to avoid potential spikes which may ruin the graph. Think about a timeSeries chart showing the temperature trend with values of
20, 21, 25, -9999, 32 degrees. You will get a huge bottom spike if not skipping the -9999 (a sample noData value).
Also, csv result will report an empty value to signal noData for that time.
A change has also been made to GetFeatureInfo by supporting a new vendor param to take care of noData results.
If there isn’t any objection, I would backport that tomorrow.
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I will also do the backport to 2.15.x on Monday if no objections.
Daniele
Daniele Romagnoli
