[Geoserver-devel] Backporting improvements for PagedUniqueProcess
any objections to backport GEOS-6806 and related GEOT-4961 to 2.6.x?
Thanks
Mauro Bartolomeoli
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
So what do these do?
  • PagedUniqueProcess limits not always working
  • JDBCDataStore should delegate to LimitingVisitor.hasLimits
So these combine to let us page through a process result?
On 16 April 2015 at 09:33, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Thanks
Mauro Bartolomeoli
@mauro_bart
BPM Camp - Free Virtual Workshop May 6th at 10am PDT/1PM EDT
Develop your own process in accordance with the BPMN 2 standard
Learn Process modeling best practices with Bonita BPM through live exercises
http://www.bonitasoft.com/be-part-of-it/events/bpm-camp-virtual- event?utm_
source=Sourceforge_BPM_Camp_5_6_15&utm_medium=email&utm_campaign=VA_SF
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.coms.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Jody Garnett
Hi Jody,
both commits are needed to fix an edge case of the PagedUnique WPS process.
The PagedUnique process is a process that returns all the unique (distinct) values of a specified attribute in a FeatureType. The process has the ability to “paginate” results with a couple of inputs to specify offset and max results.
The process uses Geotools UniqueVisitor and this is optimized in JDBCDataStore to trigger usage of queries with distinct and paging operators, when available in the SQL dialect.
The edge case that was not working prior to these commits was the usage of the process in combination with WFS service maxFeatures configuration, where the maxFeatures was lower than the total number of rows of a database table. In that case, the distinct clause was applied “after” WFS maxFeatures limit application, so not all unique values could be extracted (also if the # of unique values would have been lower than maxFeatures). The fix allows distinct to happen before any limit is applied.
The fix is already on 2.7.0 and master. I waited a bit to backport to see if any complaints of breaking other use cases could arise (you know, JDBCDataStore optimization code can always trigger weird behaviours on some database). Now I am quite confident that the fix is not breaking other stuff, so I think it’s time to backport before the next 2.6.x release.
Thanks
Mauro
2015-04-17 1:28 GMT+02:00 Jody Garnett <jody.garnett@anonymised.com>:
Jody Garnett
Thanks
Mauro Bartolomeoli
@mauro_bart
GeoTools-Devel@lists.sourceforge.net
@mauro_bart
