[Geoserver-devel] Backporting monitoring improvement
I’ve recently committed on master an improvement on monitoring that allows to record the hit/miss
and miss reason for GWC request and direct integration requests.
It’s a small change, but formally it’s an improvement, not a bug fix, so I did not backport it to stable yet.
Two questions:
  • Anyone worried about a backport in due time (20+ days from now)
  • Anyone worried about a backport sooner than that?
    In the meantime we are testing it on a demo server that deploys master daily.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Four days, no answer, I guess nobody is particularly concerned.
Not even with a backport sooner than the one month?
On Fri, Apr 20, 2018 at 12:39 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Two questions:
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Catching up on email, the monitoring api is not heavily used so I am not surprise at the lack of response.
I think as long as the addition is done in a way that does not break backwards compatibility doing a back port is fine. Do you have a pressing reason to ask for a back port sooner? Perhaps to get the change information the next stable release …
On 20 April 2018 at 03:39, Andrea Aime <andrea.aime@anonymised.com> wrote:
Two questions:
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
That sounds useful. Backport in due time is fine. Do you have a need for an earlier backport? How much earlier? 19 days or now? I have no objection if you have a need, but, as you note, it is an excursion from the rules.
Kind regards,
Ben.
wrote:
I've recently committed on master an improvement on monitoring that allows
It's a small change, but formally it's an improvement, not a bug fix, so I
Two questions:
    - Anyone worried about a backport in due time (20+ days from now)
    - Anyone worried about a backport sooner than that?
daily.
Ing. Andrea Aime
@geowolf
Technical Lead
Check out the vibrant tech community on one of the world's most
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/&gt;
New Zealand
On Tue, Apr 24, 2018 at 8:03 PM, Jody Garnett <jody.garnett@anonymised.com>
I think that GeoSolution won't stand up any server without it installed :-p
Yet, I understand, without a good setup for consuming the audit logs, it's
not so useful.
Eh, the only thing that I cannot guarantee is gs-monitoring-hibernate
backwards compatibility. But see the other thread
about lowering the module down to community status.
Yes, that was the idea. See above, for us monitoring (gs-monitor-core) is a
important module and
we're looking forward to get the extra information, an unexpected about of
"tiled=true" request
that are not hitting the cache might point to a mis-configuration on the
client side (gridset) or
on the server side (mis-configured filter parameter for example)
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea I think this is a low risk change and would be in support of you back porting the change for the next release.
Jody Garnett
On Tue, Apr 24, 2018 at 8:03 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I think that GeoSolution won’t stand up any server without it installed :-p
Yet, I understand, without a good setup for consuming the audit logs, it’s not so useful.
Eh, the only thing that I cannot guarantee is gs-monitoring-hibernate backwards compatibility. But see the other thread
Yes, that was the idea. See above, for us monitoring (gs-monitor-core) is a important module and
we’re looking forward to get the extra information, an unexpected about of “tiled=true” request
that are not hitting the cache might point to a mis-configuration on the client side (gridset) or
Ing. Andrea Aime
@geowolf
Technical Lead
