In Mapserver it is possible to configure extra contents to be included in the zipped output. That could be the copyright/license text, tailored metadata etc. Have you considered this? Some user either on geoserver-users or gis.stackexchange actually was after such feature.
You can read more about this rather cool configuration option “wfs_additional_files_in_output” https://github.com/mapserver/mapserver/issues/4884
-Jukka Rahkonen-
Andrea Aime wrote:
On Sat, Oct 31, 2015 at 7:29 PM, Jody Garnett <jody.garnett@…403…> wrote:
Sorry thought that was an implementation detail, rather than API.
I had considered facade ( good for code examples and ease of use, but for parameter documentation as you indicated). param object does not help much as you may as well do your worker class.
Hum… ok, I assume I’ll move on my original plan then (I don’t see any focused feedback above).
I had also considered something like the internals of your feature process implementations so saving to a zip could be put at the end of a process chain.
That would be a ProcessParameterIO then, we already have one doing that job calling onto the WFS output format.
A process that zips its own outputs is badly designed, that breaks ability to chain it, a well designed one goes
out with SimpleFeatureCollection and allows other processes to consume (chaining), and PPIOs to encode (in whatever
format they see fit)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
