[Geoserver-devel] Backporting spring and jetty changes
Hey folks, I wanted to get a feel for how devs would feel about back porting the recent jetty and spring upgrades to the 2.8.x branch? I’ve been working with them on master without any issues, not sure if anyone else has run into any hitches though.
If people do think this is a safe back port is now (with a 2.8 release pretty fresh out the door) a good time?
Thanks!
-Justin
Now that CITE tests have passed on master we can think about it :slight_smile: Master has not quite had the testing it usually does.
Let me check if now is a good time to back port, what were the bug fixes associated with a sprint / jetty upgrade again? Or is just for better compatibility.
On 26 November 2015 at 09:25, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Thanks!
-Justin
Go from Idea to Many App Stores Faster with Intel(R) XDK
Give your users amazing mobile app experiences with Intel(R) XDK.
Use one codebase in this all-in-one HTML5 development environment.
Design, debug & build mobile apps & 2D/3D high-impact games for multiple OSs.
http://pubads.g.doubleclick.net/gampad/clk?id=254741551&iu=/4140
Geoserver-devel mailing list
Jody Garnett
No specific bug fixes associated with the upgrade, it’s just bringing the libraries up to a version that are actually maintained/supported by the respective projects. And since I have a mandate to do it at the moment I thought I would offer.
Jody Garnett
Thanks!
-Justin
Nifty, I like the idea - but we should wait to hear back from others.
On 26 November 2015 at 14:18, Justin Deoliveira <jdeolive@anonymised.com> wrote:
On Thu, Nov 26, 2015 at 2:41 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
Thanks!
-Justin
Hi Justin,
this one had me thinking a while :slight_smile:
So, there are two separate things. The first one is the Spring upgrade. It’s an upgrade between
two minor versions, had a single commit, basically just the version number change in the pom files, worked fine.
The Spring integration is exercised by our tests and by the CITE tests, all of them seem to be working fine.
An upgrade of the library that wires everything is still risky, but given the above I’m not too concerned… let’s make that a +0?
I believe the Jetty upgrade is more contentious, more reward and more risk.
The Jetty we are shipping with on 2.8.x is a bit of an horror, old, inefficient, with known security risks, so an
upgrade is very much welcomed.
Testing wise however we are coming out pretty light though. We had the CITE tests running on master for a few
days, and I believe some people tested it interactively… but the stable series is meant for production, so I believe
we need more than that.
And then we have the installers: how many people have tried the windows and OSX installer with the new Jetty and can attest they are working?
Possibly a number <= 1, assuming Justin has had the time to check both when making the Jetty upgrade :-p
So… from this point of view I’d be -1 on the Jetty upgrade, but at the same time… it would be so good…
so what can be done to mitigate those risks?
Here is a few of ideas, hopefully others will add more/better ones:
  • Have a well known demo instance of GeoServer somewhere use the new bin package and see how it stands the load
  • We could run some of the benchmarking exercises on top of it
  • To have people use the installers, maybe cut a milestone release out of trunk? We have a few new features
    already in there to sweeten the pot and make it more interesting for people to kick its tires
What do you think?
On Thu, Nov 26, 2015 at 6:25 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Thanks!
-Justin
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I am willing to test a nightly build.
I note that OpenGeo Suite ships with a slightly newer version of Jetty and I would be in favour of upgrading both for consistency.
Thanks!
-Justin
Ing. Andrea Aime
@geowolf
Technical Lead
Fair enough. I will say that I have to do the back port regardless for a project but I can easily work from a branch in my own fork for now if folks decide it’s not worth the risk.
As for mitigating the risk, your suggestions all sound good. Regarding updating a demo server the only people I know that run a stable GeoServer demo are Boundless and GeoSolutions. So I’ll let those devs comment on if they want to do an upgrade. I can cut a 2.8.x build with the library upgrades or they can grab a nightly from master. Just let me know.
As for running benchmarks is there a test suite that is readily available and easy to set up? Depending on how much work is involved there I can volunteer some time to put to that.
As for a milestone release from master I can also put some time toward that as long as it’s something I can bust off in a few hours time frame. If there is going to be more ceremony around it not sure how much time I can devote to it at the moment.
Thanks!
-Justin
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Nov 27, 2015 at 5:54 PM, Justin Deoliveira <jdeolive@anonymised.com>
I'll check internally. At the time of writing the demo servers are pretty
old, we have 2.6.x on both:
http://demo.geo-solutions.it/geoserver/web/
http://demo.opengeo.org/geoserver/web/
Grabbing the data is the main pain point (tens of GB worth of). But I can
run the benchmarks locally if we get the other mitigation bits moving.
I'd say, little or not ceremony needed, just run the release scripts on
master and make a quick blog post explaining why we did it? I can help with
a short description of the new features I've implemented so far
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Justin:
Following up on this one based on test results - the milestone release is mostly successful:
  • linux: bin download works
  • windows: Jukka tested - my understanding is the bin download worked, but installer may be untested
  • osx: both bin and app install did not work (moving JAI jars to jetty/lib folder allowed it to start)
If we can figure out the above issue I am happy to backport.
Thanks!
-Justin
Jody Garnett
windows: Andrea tested windows installer and it functioned as expected
On 29 December 2015 at 14:04, Jody Garnett <jody.garnett@anonymised.com> wrote:
Justin:
Jody Garnett
Jody Garnett
Thanks!
-Justin
