[Geoserver-devel] Backporting spring and jetty changes
Did Andrea make a new test after he wrote what is cited in your mail below:
” - windows: Jukka tested - my understanding is the bin download worked, but installer may be untested”
Bin-zip really worked for me. Installer seems to install everything OK but startup.bat does not start Geoserver. The error is:
C:\Program Files (x86)\GeoServer 2.9-M0\bin>call "C:\Program Files (x86)\Java\jr
e1.8.0_60\bin\java.exe" -DGEOSERVER_DATA_DIR="C:\Program Files (x86)\GeoServer 2
.9-M0\data_dir" -Xmx512m -XX:MaxPermSize=128m -DSTOP.PORT=8079 -DSTOP.KEY=geoser
ver -Djetty.port=8080 -Djetty.logs="C:\Program Files (x86)\GeoServer 2.9-M0\logs
" -jar “C:\Program Files (x86)\GeoServer 2.9-M0\start.jar”
Java HotSpot™ Client VM warning: ignoring option MaxPermSize=128m; support was removed in 8.0
WARNING: Module not found [ssl]
WARNING: Nothing to start, exiting …
Usage: java -jar start.jar [options] [properties] [configs]
java -jar start.jar --help # for more information
Startup.bat is really simple and all the paths look correct. By editing the path to start.jar I got another error so I do not know yet what makes it to fail.
call “C:\Program Files (x86)\Java\jre1.8.0_60\bin\java.exe” -DGEOSERVER_DATA_DIR=“C:\Program Files (x86)\GeoServer 2.9-M0\data_dir” -Xmx512m -XX:MaxPermSize=128m -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -Djetty.port=8080 -Djetty.logs=“C:\Program Files (x86)\GeoServer 2.9-M0\logs” -jar “C:\Program Files (x86)\GeoServer 2.9-M0\start.jar”
-Jukka-
Jody Garnett wrote:
windows: Andrea tested windows installer and it functioned as expected
Jody Garnett
On 29 December 2015 at 14:04, Jody Garnett <jody.garnett@…403…> wrote:
Justin:
Following up on this one based on test results - the milestone release is mostly successful:
  • linux: bin download works
  • windows: Jukka tested - my understanding is the bin download worked, but installer may be untested
  • osx: both bin and app install did not work (moving JAI jars to jetty/lib folder allowed it to start)
If we can figure out the above issue I am happy to backport.
Jody Garnett
On 26 November 2015 at 09:25, Justin Deoliveira <jdeolive@…403…> wrote:
Hey folks, I wanted to get a feel for how devs would feel about back porting the recent jetty and spring upgrades to the 2.8.x branch? I’ve been working with them on master without any issues, not sure if anyone else has run into any hitches though.
If people do think this is a safe back port is now (with a 2.8 release pretty fresh out the door) a good time?
Thanks!
-Justin
Go from Idea to Many App Stores Faster with Intel(R) XDK
Give your users amazing mobile app experiences with Intel(R) XDK.
Use one codebase in this all-in-one HTML5 development environment.
Design, debug & build mobile apps & 2D/3D high-impact games for multiple OSs.
http://pubads.g.doubleclick.net/gampad/clk?id=254741551&iu=/4140
Geoserver-devel mailing list
On Wed, Dec 30, 2015 at 9:38 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
I tested it during the last PSC meeting, because we were talking about the
M0 release being blocked, Jody though
the issue was showing up on all OSs, but I remembered Linux working for me,
so I first tested Linux again,
and then Windows using the installer on a clean machine (uninstalled the
previous GeoServer before adding
the new one).
(x86)\Java\jr
(x86)\GeoServer 2
-DSTOP.KEY=geoser
2.9-M0\logs
" -jar "C:\Program Files (x86)\GeoServer 2.9-M0\start.jar"
Java HotSpot(TM) Client VM warning: ignoring option MaxPermSize=128m;
WARNING: Nothing to start, exiting ...
it to fail.
call "C:\Program Files (x86)\Java\jre1.8.0_60\bin\java.exe"
-DGEOSERVER_DATA_DIR="C:\Program Files (x86)\GeoServer 2.9-M0\data_dir"
2.9-M0\logs" -jar "C:\Program Files (x86)\GeoServer 2.9-M0\start.jar"
I don't know what's going on there, although it's similar to what Jody is
seeing... could it be some incompatibility with a previous install?
Or maybe just draw of the luck when loading up jars from the file system?
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
