Hello,
Just reminder about this (since that 2.9 release is out).
I have made two pull request for this (one for GS and another one for GWC):
- https://github.com/GeoWebCache/geowebcache/pull/414
- https://github.com/geoserver/geoserver/pull/1732
Nuno Oliveira
Le jeudi 21 juillet 2016 à 14:56 +0200, Simone Giannecchini a écrit :
Ciao Jody,
no worries, we can do this backport after the 2.9 release.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Wed, Jul 20, 2016 at 9:46 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
> We expect a 2.9.x and 2.8.x release shortly, thus I would be very hesitant
> to back port anything even remotely scary this week. If the backport being
> included in the next release is important for you / your customer you may
> wish to back up the release process with testing the preflight artifacts.
> Jody Garnett
> On 16 July 2016 at 02:56, Nuno Oliveira <nuno.oliveira@anonymised.com>
> wrote:
> > Hi,
> > The work done to improve WMTS INSPIRE compatibility was scattered along
> > GeoServer and GeoWebCache.
> > GeoServer work:
> > [GEOS-7591] Allow WMTS service to be invoked per workspace
> > [GEOS-7592] Add WMTS web admin page
> > [GEOS-7593] Add ISNPIRE required metadata to WMTS get capabilities
> > result
> > GeoWebCache work:
> > Resolves #391, add extensions points in WMTS service
> > Resolves #392, allow a tile layer to provide styles legend information
> > This work has been contributed through three pull requests (already merged
> > on master):
> > https://github.com/geoserver/geoserver/pull/1646
> > https://github.com/geoserver/geoserver/pull/1645
> > https://github.com/GeoWebCache/geowebcache/pull/393
> > I would like to backport this work to GeoServer 2.8.x and GeoServer 2.9.x
> > and GWC respective versions.
> > I would like to start the discussion right away about what parts of this
> > work the community is ok to
> > backport and with which timings.
> > Regards,
> > Nuno Oliveira
> > Nuno Miguel Carvalho Oliveira
> > @nmcoliveira
> > Software Engineer
> > GeoSolutions S.A.S.
> > Italy
> > http://twitter.com/geosolutions_it
> > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> > Le informazioni contenute in questo messaggio di posta elettronica e/o
> > da considerarsi strettamente riservate. Il loro utilizzo è consentito
> > esclusivamente al destinatario del messaggio, per le finalità indicate
> > nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il
> > destinatario, Vi preghiamo cortesemente di darcene notizia via e
> > -mail e di procedere alla distruzione del messaggio stesso, cancellandolo
> > dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo
> > per finalità diverse, costituisce comportamento contrario ai
> > principi dettati dal D.Lgs. 196/2003.
> > The information in this message and/or attachments, is intended solely for
> > the named addressee(s) and may be confidential or proprietary in nature or
> > covered by the provisions of privacy act (Legislative Decree
> > June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in
> > accord with its purpose, any disclosure, reproduction, copying,
> > distribution, or either dissemination, either whole or partial, is
> > strictly forbidden except previous formal approval of the named
> > addressee(s). If you are not the intended recipient, please contact
> > immediately the sender by telephone, fax or e-mail and delete the
> > information in this message that has been received in error. The sender
> > does not give any warranty or accept liability as the content,
> > accuracy or completeness of sent messages and accepts no responsibility
> > for changes made after they were sent or for other risks which
> > arise as a result of e-mail transmission, viruses, etc.
> > What NetFlow Analyzer can do for you? Monitors network bandwidth and
> > traffic
> > patterns at an interface-level. Reveals which users, apps, and protocols
> > are
> > consuming the most bandwidth. Provides multi-vendor support for NetFlow,
> > J-Flow, sFlow and other flows. Make informed decisions using capacity
> > planning
> > reports.http://sdm.link/zohodev2dev
> > _______________________________________________
> > Geowebcache-devel mailing list
> > Geowebcache-devel@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geowebcache-devel
> What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
> patterns at an interface-level. Reveals which users, apps, and protocols are
> planning
> Geoserver-devel mailing list
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
@nmcoliveira
Software Engineer
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
