[Geoserver-devel] Backup-Restore without embedded GWC
Been playing around with the backup-restore community module (great job Alessio & co on it BTW). I'm trying to use it in an environment that doesn't include embedded GWC and running into a slight issue:
Caused by: org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named 'gwcGeoServervConfigPersister' available
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanDefinition(DefaultListableBeanFactory.java:687) ~[spring-beans-4.3.6.RELEASE.jar:4.3.6.RELEASE]
  at org.springframework.beans.factory.support.AbstractBeanFactory.getMergedLocalBeanDefinition(AbstractBeanFactory.java:1207) ~[spring-beans-4.3.6.RELEASE.jar:4.3.6.RELEASE]
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:284) ~[spring-beans-4.3.6.RELEASE.jar:4.3.6.RELEASE]
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:202) ~[spring-beans-4.3.6.RELEASE.jar:4.3.6.RELEASE]
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:275) ~[spring-beans-4.3.6.RELEASE.jar:4.3.6.RELEASE]
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197) ~[spring-beans-4.3.6.RELEASE.jar:4.3.6.RELEASE]
  at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1081) ~[spring-context-4.3.6.RELEASE.jar:4.3.6.RELEASE]
  at org.geoserver.platform.GeoServerExtensions.getBean(GeoServerExtensions.java:238) ~[gs-platform-2.10-20170209.132836-1205.jar:2.10-SNAPSHOT]
  at org.geoserver.platform.GeoServerExtensions.bean(GeoServerExtensions.java:293) ~[gs-platform-2.10-20170209.132836-1205.jar:2.10-SNAPSHOT]
  at org.geoserver.platform.GeoServerExtensions.bean(GeoServerExtensions.java:284) ~[gs-platform-2.10-20170209.132836-1205.jar:2.10-SNAPSHOT]
  at org.geoserver.backuprestore.tasklet.CatalogBackupRestoreTasklet.hardRestore(CatalogBackupRestoreTasklet.java:415) ~[gs-backup-restore-core-2.10-20170209.133347-845.jar:2.10-SNAPSHOT]
  at org.geoserver.backuprestore.tasklet.CatalogBackupRestoreTasklet.doRestore(CatalogBackupRestoreTasklet.java:290) ~[gs-backup-restore-core-2.10-20170209.133347-845.jar:2.10-SNAPSHOT]
  ... 5 common frames omitted
but looking at the code it seems like the intent was for this to actually work without GWC available? There is a null check at that point in the code for the gwcGeoServervConfigPersister, it just seems to fail because an exception is thrown instead.
// Restore GWC Configuration bits
if (GeoServerExtensions.bean("gwcGeoServervConfigPersister") != null) {
    restoreGWCSettings(sourceRestoreFolder, dd.get(Paths.BASE));
Would there be any objection to adding a catch block for NoBeanDefinitionFoundException? The only issue I see there is that it would mean that the fact that GWC restore failed in that specific instance. Maybe there would be a better way to do it?
Devon
Hi Devon,
good catch. Yes the “NoBeanDefinitionFound” Exception should be catch there and maybe on some other places where similar checks are made.
I will prepare a patch asap and update the community module hopefully today.
Alessio.
On Tue, Feb 14, 2017 at 8:43 PM, Devon Tucker <dtucker@anonymised.com> wrote:
Been playing around with the backup-restore community module (great job Alessio & co on it BTW). I’m trying to use it in an environment that doesn’t include embedded GWC and running into a slight issue:
Caused by: org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named ‘gwcGeoServervConfigPersister’ available
… 5 common frames omitted
if (GeoServerExtensions.bean(“gwcGeoServervConfigPersister”) != null) {
Devon
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
Hi Devon,
commit done
https://github.com/geoserver/geoserver/commit/a9573b74f9c6840131f2d4a37b7c24e330d8337c
Alessio.
On Wed, Feb 15, 2017 at 9:53 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hi Devon,
Alessio.
Best Regards,
Alessio Fabiani.
@alfa7691
Best Regards,
Alessio Fabiani.
@alfa7691
Devon
Geoserver-devel@anonymised.comrge.net
