Thanks for the notes, Andrea, this is super helpful. Follow-ups, below.
all keys are case insenstive, all values are case sensitive.
Okay, but I do see that service=WPS works as well as service=wps. Just GeoServer being nice, though, I guess.
- the buffer in the example returns a square... correct answer given the params, but a little
outside what one would expect from a buffer operation
I was looking for an example that would be simple to understand from just looking at the coordinates. If I had created a circle (or polygon equivalent), it might be more real world, but the numbers might not be so understandable. But I could change the example, though, if you thought it valuable. It was just the first process I came up with.
Also, found it interesting that as is, the values were like -10.00000000067 instead of -10.0.
- in the geoserver processes paragraph you say "These functions have the added bonus
of being able to operate on existing layers in GeoServer, and can even write the output
to a new GeoServer layer".
Actually any process can work against existing GS layers, it just
Okay. How should I categorize the differences between the gs: and the JTS: processes? (Or is there no important distinction?) I saw that the request builder had an extra entry for VECTOR_LAYER on the gs: processes, which is why I made the note.
- the trick GS uses to get data off the internal WFS/WCS is to use a special URL
for the wfs/wcs server, http://geoserver/wfs and
http://geoserver/wcs (if memory
serves me right) and that part is just a GS convention, it's not
anything that is
part of the standard
Okay, I'll make a note of that.
- that said GS can feed off any remote WFS/WCS just fine (provided the chosen
output format can be parsed by GS), and in general, but any remote call
whatsoever that returns something parseable (it might be a php
script returning GML
for example)
I'm pretty sure I follow this, but if an example lived somewhere it would be great to see it.
Mike Pumphrey
OpenGeo - http://opengeo.org
On 2/2/2011 4:43 AM, Andrea Aime wrote:
On Wed, Feb 2, 2011 at 2:15 AM, Mike Pumphrey<mike@anonymised.com> wrote:
Hi there. I just submitted a patch with some basic WPS docs.
http://jira.codehaus.org/browse/GEOS-4350
To make it easier for people to read (and to see the graphics), I committed this first draft on 2.1.x. It should show up here after the next nightly build:
http://docs.geoserver.org/stable/en/user/extensions/wps/index.html
Feedback appreciated.
A few notes:
- "the names of processes are case sensitive". Actually in OGC style
request that is normal,
all keys are case insenstive, all values are case sensitive. Process
names are no exception,
just like feature type names, coverage names, and wms layer names
the added bonus
needs to be able to
consume a feature collection or a grid coverage. And not even that
in some cases, the
JTS processes can feed off the GS layers via the internal WFS
request if that one is
chained in gs:CollectGeometries which turns the feature collection
into a single geometry
(it collects everything into a big multi-geometry)
anything that is
for example)
