[Geoserver-devel] bc_roads and geoserver/conf?
Hi
I installed geoServer.war, version 1.2 in my Tomcat.
I did not do any modification on any properties files.
http://localhost:8080/geoserver/wfs/GetCapabilities gives me the right xml
file.
However, when I try to access:
http://localhost:8080/geoserver/wms?request=GetMap&layers=bc_roads&bbox=489153,5
433000,529000,5460816&width=400&height=200&srs=EPSG:27354&styles=normal&Format=i
mage/png
It gives the errors in the email below.
Do I need to configure bc_roads somewhere?
Acutually I am a little bit confused about the installation notes. It
keeps referring to geoserver/conf, but I do not see such a dir. Am I
supposed to create one myself? I found services.xml and catalog.xml files
in WEB-INF dir.
Please help. Thanks.
I am so far impressed with the vision and archicture of geoServer.
Changqing
ServiceException code="">bc_roads: no such layer on this server:
java.util.NoSuchElementException: there is no FeatureTypeConfig named
bc_roads configured in this server at
org.vfny.geoserver.global.Data.getFeatureTypeInfo(Data.java:982) at
I figured out the problem:
bc_roads needs to be referred as topp:bc_roads
The document should be motified.
Changqing
On Sun, 4 Apr 2004, Changqing Zhou wrote:
Hi
file.
mage/png
in WEB-INF dir.
Changqing
This SF.Net email is sponsored by: IBM Linux Tutorials
Free Linux tutorial presented by Daniel Robbins, President and CEO of
GenToo technologies. Learn everything from fundamentals to system
administration.http://ads.osdn.com/?ad_id=1470&alloc_id=3638&op=click
Geoserver-devel mailing list
