[Geoserver-devel] beanutils exception when trying to look at workspaces
Hello,
I get an error when navigating to the Workspaces page, and the Styles page.
To give some background.
I have set-up Geoserver to authenticate against Active Directory which works.
I’m running Geoserver 2.5 on Glassfish v4 with security manager enabled.
Several permissions had to be added to the policy file to get the functionality to where it is now, am I missing one?
I’m seeing a beanutils exception toward the bottom, trying to call a getter that apparently doesn’t exist. I’m not sure why this is aggravated by enabling security manager, but perhaps it is bubbling up?
Any help would be appreciated. I have to keep security manager enabled, and can not allow all permissions to the application.
//permissions to allow GeoServer to run
grant codebase “file:${com.sun.aas.instanceRoot}/applications/geoserver/-” {
permission java.lang.RuntimePermission “getenv.";
permission com.sun.tools.attach.AttachPermission “createAttachProvider”;
permission java.lang.RuntimePermission "accessClassInPackage.com.sun.imageio.
permission java.util.logging.LoggingPermission “control”;
permission java.lang.RuntimePermission “createClassLoader”;
permission java.lang.reflect.ReflectPermission “suppressAccessChecks”;
permission java.io.FilePermission “${com.sun.aas.instanceRoot}/applications/geoserver/-”, “read, write, execute, delete”;
permission java.security.SecurityPermission “putProviderProperty.BC”;
permission java.security.SecurityPermission “insertProvider.BC”;
permission java.lang.RuntimePermission “modifyThread”;
permission java.lang.RuntimePermission “preferences”;
permission java.lang.RuntimePermission “shutdownHooks”;
permission java.lang.RuntimePermission “getClassLoader”;
permission java.io.SerializablePermission “enableSubclassImplementation”;
permission java.io.SerializablePermission “enableSubstitution”;
permission java.util.PropertyPermission “*”, “read,write”;
permission org.apache.wicket.authorization.strategies.role.metadata.InstantiationPermissions “authorizeAll”;
org.apache.wicket.WicketRuntimeException: Error attaching this container for rendering: [MarkupContainer [Component id = listContainer]] at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1765) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Page.onBeforeRender(Page.java:1531) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.Component.prepareForRender(Component.java:2292) at org.apache.wicket.Page.prepareForRender(Page.java:1521) at org.apache.wicket.Component.prepareForRender(Component.java:2329) at org.apache.wicket.Page.renderPage(Page.java:892) at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:261) at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105) at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258) at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484) at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138) at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778) at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) at sun.reflect.GeneratedMethodAccessor159.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:323) at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:321) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAsPrivileged(Subject.java:536) at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:356) at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:214) at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1676) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:344) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74) at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70) at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:115) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68) at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87) at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173) at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256) at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:90) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:197) at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:194) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:316) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:160) at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:734) at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:673) at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:99) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:174) at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:357) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:260) at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:188) at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:191) at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:168) at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:189) at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:119) at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:288) at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:206) at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:136) at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:114) at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77) at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:838) at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:113) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:115) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:55) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:135) at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:564) at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:544) at java.lang.Thread.run(Thread.java:744) Caused by: java.lang.RuntimeException: Could not find property name in class com.sun.proxy.$Proxy203 at org.geoserver.web.wicket.GeoServerDataProvider$BeanProperty.getPropertyValue(GeoServerDataProvider.java:507) at org.geoserver.web.wicket.GeoServerDataProvider$PropertyComparator.compare(GeoServerDataProvider.java:580) at java.util.TimSort.countRunAndMakeAscending(TimSort.java:324) at java.util.TimSort.sort(TimSort.java:189) at java.util.TimSort.sort(TimSort.java:173) at java.util.Arrays.sort(Arrays.java:659) at java.util.Collections.sort(Collections.java:217) at org.geoserver.web.wicket.GeoServerDataProvider.iterator(GeoServerDataProvider.java:192) at org.apache.wicket.markup.repeater.data.DataViewBase$ModelIterator.(DataViewBase.java:109) at org.apache.wicket.markup.repeater.data.DataViewBase.getItemModels(DataViewBase.java:76) at org.apache.wicket.markup.repeater.AbstractPageableView.getItemModels(AbstractPageableView.java:107) at org.apache.wicket.markup.repeater.RefreshingView.onPopulate(RefreshingView.java:94) at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:131) at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:121) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) … 177 more Caused by: java.lang.NoSuchMethodException: Unknown property ‘name’ at org.apache.commons.beanutils.PropertyUtilsBean.getSimpleProperty(PropertyUtilsBean.java:1122) at org.apache.commons.beanutils.PropertyUtilsBean.getNestedProperty(PropertyUtilsBean.java:686) at org.apache.commons.beanutils.PropertyUtilsBean.getProperty(PropertyUtilsBean.java:715) at org.apache.commons.beanutils.PropertyUtils.getProperty(PropertyUtils.java:290) at org.geoserver.web.wicket.GeoServerDataProvider$BeanProperty.getPropertyValue(GeoServerDataProvider.java:503) … 193 more
