I would like to give Marlin (http://www.geo-solutions.it/blog/developerss-corner-achieving-extreme-geoserver-scalability-with-the-new-marlin-vector-rasterizer/)
better visibility for the GeoServer users, in order to support the sole developer of the library, and show that
more and more software packages are offering it as an option (gvsig-ce is going to have it in the next release,
as it greatly speeds up rendering of point clouds, lidar data I presume).
The ideal thing would be to have an extension module, as it would end up showing in the downloads,
but Marlin is something that requires almost nothing of GeoServer, it needs to be installed in the JRE/JDK
instead and then some startup options need to be provided.
I guess the second best option would be to write a tutorial on how to use it, with detailed instructions
on how to make it work with Windows installations for example.
What do you think, ideas?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
