Hi-
I have been using GeoServer beta1 and making good progress generating maps, where the maps are stored in a Postgres PostGIS database. I set up a beta3 server and configured it exactly like the beta1 server, but it's not working. There is only this error in the log:
62923 [SEVERE] rg.geotools.renderer.lite.LiteRenderer2$DefaultRenderListener - Could not parse WKB representations - found no Geometries
This error is repeated hundreds of times, every time I try to generate a map. I have absolutely no clue what is the problem here. I also tried the beta2 release earlier and could not get it to work. If I can't get beta3 to work using the existing PostGIS database, then I will probably have to give up trying to use GeoServer completely.
Bob Cook
racook@anonymised.com
