[Geoserver-devel] Bizarre unit test failures due to disallowed entity resolution
I’m getting unit test failures in several tests of org.geoserver.wfs.v1_1.GetFeatureTest due to the following exception which seems to relate to the GEOS-7032 fix
org.xml.sax.SAXException: Entity resolution disallowed for file:/home/smithkm/og-proj/geoserver/src/ows/target/classes/org/geoserver/ows/xml/v1_0/owsAll.xsd
The failures seem to be stateful, depending on the other unit tests being run, which commit I’m on, etc. It’s not as simple (for a rather complicated definition of simple) as one previous test leaving some state in place that breaks the test. There’s some more complicated interaction of different factors going on that I haven’t figured out. The only thing that’s consistent is that the tests will pass when run as part of the full set of GeoServer unit tests, and will pass when run in isolation, regardless of which of my machines, which commit I build from, which JDK I use (Oracle 7, Oracle 8, OpenJDK 7).
in
com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaLoader.resolveDocument(XSDDescription, Map, XMLEntityResolver)
it’s trying to look up
…/…/ows/1.0.0/owsAll.xsd
from
jar:file:/home/smithkm/.m2-normal/repository/org/geotools/xsd/gt-xsd-wfs/14-SNAPSHOT/gt-xsd-wfs-14-SNAPSHOT.jar!/org/geotools/wfs/v1_1/wfs.xsd
and then “expanding” that to get
This then runs afoul of the restriction on looking up XSDs from the local file system.
In the non failing case, there’s no attampt to resolve owsAll.xsd in XMLSchemaLoader.resolveDocument at all.
Kevin,
are you seeing these failures in Maven or Eclipse?
If the latter, please refer to the off-list vulnerability discussion "GeoServer XXE bypass ticket". I have included a couple of these below for your convenience.
Is something (like an Eclipse build) copying these resources into a target directory where it is then captured by Eclipse transitive dependency inclusion? Have you built with clean and eclipse:clean and a full workspace clean and rebuild and then an Eclipse restart (and stand up and run around your desk three times)?
Torben, do you expect unit tests to pass in Eclipse?
Kind regards,
Ben.
-------- Forwarded Message --------
Subject: Re: GeoServer XXE bypass ticket
Date: Fri, 03 Jul 2015 07:37:00 +1200
CC: [...] Kevin Smith <ksmith@anonymised.com> [...]
classpath dependencies are resolved as file: URLs if they are resources
of the current module or project dependencies in Eclipse (i.e. other
GeoServer modules), and as jar: URLs if they are GeoTools module
dependencies in Maven or GeoTools dependencies.
The standard Eclipse setup (GeoServer modules are project dependencies,
GeoTools dependencies are jar files referenced from your Maven repo)
will give different URL types; Maven always resolves dependencies as
jars from the Maven repo, even between GeoServer modules.
You may get more failures in Eclipse! A sneaky solution would be to move
xsd dependencies into GeoTools and then forbid file: URLs.
Kind regards,
Ben.
Date: Fri, 03 Jul 2015 09:19:06 +1200
there is already a copy of wcsAll.xsd in the GeoTools net.opengis.wcs
module:
modules/ogc/net.opengis.wcs/schemas/wcs/1.1.1/wcsAll.xsd
It looks like it was only used for generating the bindings (with
xmlcodegen), and does not appear to be included in the jar for this
module. Including it may introduce more problems as this schema has
cross-source imports, e.g from wcsGeoCoverage.xsd (note ../../):
<import namespace="http://www.opengis.net/ows/1.1&quot;
schemaLocation="../../ows/1.1.0/owsAll.xsd"/>
gt-xml SchemaResolver was written to overcome these problems and to
allow resolution of test dependencies across jar files. It is not just
for downloading schemas.
Kind regards,
Ben.
On 31/07/15 08:40, Kevin Smith wrote:
I'm getting unit test failures in several tests of
being run, which commit I'm on, etc. It's not as simple (for a rather
state in place that breaks the test. There's some more complicated
interaction of different factors going on that I haven't figured out.
The only thing that's consistent is that the tests will pass when run as
in
  it's trying to look up
../../ows/1.0.0/owsAll.xsd
from
and then "expanding" that to get
local file system.
In the non failing case, there's no attampt to resolve owsAll.xsd in
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
The tests should pass in eclipse (although I can’t be certain), I moved everything that is viable to move upstream to geotools. Based on the failure, it looks like owsAll.xsd is still in geoserver; maybe try removing the ows module from you eclipse setup then adding it to your build bath as a standalone jar?
The tests should certainly pass in maven, I made sure that all the file resolution stuff would work there.
Torben
On Thu, Jul 30, 2015 at 1:57 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Kevin,
If the latter, please refer to the off-list vulnerability discussion “GeoServer XXE bypass ticket”. I have included a couple of these below for your convenience.
Kind regards,
Ben.
CC: […] Kevin Smith <ksmith@anonymised.com> […]
Kind regards,
Ben.
module:
cross-source imports, e.g from wcsGeoCoverage.xsd (note …/…/):
Kind regards,
Ben.
in
from
local file system.
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Well, removing the OWS project and replacing it with a jar seems to have fixed it in Eclipse. So the tests for the full WFS module now pass in both Eclipse and Maven. When I run larger sets of tests across modules in Maven, I still get a failure because owsAll.xsd is being resolved as a file URL.
Kevin Michael Smith
smithkm@anonymised.com
Torben
Kevin,
Kind regards,
Ben.
Kind regards,
Ben.
module:
<import namespace=“http://www.opengis.net/ows/1.1
schemaLocation=“…/…/ows/1.1.0/owsAll.xsd”/>
Kind regards,
Ben.
in
from
local file system.
Director
New Zealand
It surprises me that you still get a failure in maven, especially since the tests pass on ares Jenkins.
Torben
Kevin Michael Smith
Torben
Kevin,
Kind regards,
Ben.
Kind regards,
Ben.
module:
Kind regards,
Ben.
in
from
local file system.
Director
New Zealand
Running locating with a full maven build I make it past the wfs module …
I am getting new failures in WMS but I will start a second thread for that.
Kevin Michael Smith
Torben
Kevin,
Kind regards,
Ben.
Kind regards,
Ben.
module:
Kind regards,
Ben.
in
from
local file system.
Director
New Zealand
Jody Garnett
Here you go. I also see failures.
I see the following failures in gs-wms on OpenJDK 7 on Linux. Travis CI passes for openjdk7. In my experience, OpenJDK is sensitive to antialiasing and system installed fonts. Travis CI runs Ubuntu, and may have more or different fonts.
Failed tests: testIndexedBlackBG(org.geoserver.wms.map.GetMapIntegrationTest): Images are visibly different, found 4717 different pixels, against a threshold of 0
   testIndexed(org.geoserver.wms.map.GetMapIntegrationTest): Images are visibly different, found 4717 different pixels, against a threshold of 0
testTimeElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest): expected:<java.awt.Color[r=0,g=0,b=0]> but was:<java.awt.Color[r=255,g=255,b=255]>
testElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest): expected:<java.awt.Color[r=0,g=0,b=0]> but was:<java.awt.Color[r=255,g=255,b=255]>
testTimeRange(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest): expected:<java.awt.Color[r=0,g=0,b=0]> but was:<java.awt.Color[r=255,g=255,b=255]>
testGetMapValidValue(org.geoserver.wms.wms_1_1_1.DynamicDimensionsTest): expected:<java.awt.Color[r=0,g=0,b=0]> but was:<java.awt.Color[r=255,g=255,b=255]>
testGetMapCaseInsensitiveKey(org.geoserver.wms.wms_1_1_1.DynamicDimensionsTest): expected:<java.awt.Color[r=0,g=0,b=0]> but was:<java.awt.Color[r=255,g=255,b=255]>
Apache Maven 3.2.5 (12a6b3acb947671f09b81f49094c53f426d8cea1; 2014-12-15T06:29:23+13:00)
Maven home: /home/ben/java/maven
Java version: 1.7.0_79, vendor: Oracle Corporation
Java home: /usr/lib/jvm/java-7-openjdk-amd64/jre
Default locale: en_GB, platform encoding: UTF-8
OS name: "linux", version: "4.0.0-2-amd64", arch: "amd64", family: "unix"
Kind regards,
Director
New Zealand
The green blob in the middle is missing for these two tests. This is not a font or antialiasing problem.
Director
New Zealand
Boundless Jenkins is also failing on these tests. First failing build appears to have been triggered by this GeoTools change:
[GEOT-5175] Allow image mosaic to handle a mix of images in different color models
http://ares.boundlessgeo.com/jenkins/job/geotools-master/776/changes#detail0
Kind regards,
Ben.
Director
New Zealand
On Fri, Jul 31, 2015 at 3:47 AM, Ben Caradoc-Davies <ben@anonymised.com>
color models
Yes, I replied to one of the failed builds and said the same, and that I
would have looked into it today.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Aha, yes you did! I should not read email out of order. :slight_smile:
Director
New Zealand
It seems the builds are working again
On Fri, Jul 31, 2015 at 1:18 PM, Ben Caradoc-Davies <ben@anonymised.com4191…> wrote:
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
