Justin,
github is not playing nice with svn, breaking your community/python svn external in GeoServer trunk, and breaking my buildbot, not to mention "svn up" failing locally. Please see the evidence and links in the Jira issue:
http://jira.codehaus.org/browse/GEOS-4124
I am just about ready to disable your svn external. I am sure you put it there for a reason, and I am reluctant to inconvenience you. Is there anything that svn clients can do to workaround this problem?
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Ahh right, sorry was going to look into this but totally forgot. Yes by all means let’s disable it for now. Although I just did an svn up in that module and the external worked (but i did see it fail as well last week).
Anyways, external is now turned off. Sorry for the inconvenience.
-Justin
On Tue, Sep 7, 2010 at 6:46 AM, Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com wrote:
Justin,
github is not playing nice with svn, breaking your community/python svn external in GeoServer trunk, and breaking my buildbot, not to mention “svn up” failing locally. Please see the evidence and links in the Jira issue:
Kind regards,
Justin Deoliveira
OpenGeo - http://opengeo.org
No problem. Looks like an intermittent fault. Enough people have complained to githib that they should be motivated to fix it.
Kind regards,
Ben.
On 07/09/10 13:22, Justin Deoliveira wrote:
Ahh right, sorry was going to look into this but totally forgot. Yes by all means let's disable it for now. Although I just did an svn up in that module and the external worked (but i did see it fail as well last week).
-Justin
On Tue, Sep 7, 2010 at 6:46 AM, Ben Caradoc-Davies<Ben.Caradoc-Davies@anonymised.com> wrote:
Justin,
Kind regards,
Justin Deoliveira
