[Geoserver-devel] Broken JAVA_OPTS handling in startup.sh
Hello
In geoserver 2.20.x the startup.sh of the platform independent binary distribution has been refactored
2.19.x:
exec “$_RUNJAVA” $JAVA_OPTS $MARLIN_ENABLER -DGEOSERVER_DATA_DIR=“$GEOSERVER_DATA_DIR” -Djava.awt.headless=true -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar start.jar
2.20.x:
IFS=$(printf ‘\n\t’)
exec “${_RUNJAVA}” “${JAVA_OPTS:–DNoJavaOpts}” “${MARLIN_ENABLER:–DMarlinDisabled}” “${RENDERER:–DDefaultrenderer}” “-Djetty.base=${GEOSERVER_HOME}” “-DGEOSERVER_DATA_DIR=${GEOSERVER_DATA_DIR}” -Djava.awt.headless=true -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar “${GEOSERVER_HOME}/start.jar”
This doesn’t allow setting multiple parameters in JAVA_OPTS anymore because it will be passed to exec as one argument.
Reproduce like this:
  1. Download and extract the zip file
  2. cd geoserver-2.20.2-bin
  3. export JAVA_OPTS=“-Xms512m -Xmx1g”
  4. bin/startup.sh
Result:
GEOSERVER_HOME environment variable not found, using current
directory. If not set then running this script from other
directories will not work in the future.
GEOSERVER DATA DIR is /vagrant/geoserver-2.20.2-bin/data_dir
Invalid initial heap size: -Xms512m -Xmx1g
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
By setting set -x before the call one can see that the parameters are passed as one argument:
  • exec java ‘-Xms512m -Xmx1g’ -Xbootclasspath/a:/vagrant/geoserver-2.20.2-bin/webapps/geoserver/WEB-INF/lib/marlin-0.9.3.jar -Dsun.java2d.renderer=org.marlin.pisces.MarlinRenderingEngine -Djetty.base=/vagrant/geoserver-2.20.2-bin -DGEOSERVER_DATA_DIR=/vagrant/geoserver-2.20.2-bin/data_dir -Djava.awt.headless=true -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar /vagrant/geoserver-2.20.2-bin/start.jar
By removing ‘IFS=$(printf ‘\n\t’)’ and removing the quotation marks from “${JAVA_OPTS:–DNoJavaOpts}” this will work again:
  • exec java -Xms512m -Xmx1g -Xbootclasspath/a:/vagrant/geoserver-2.20.2-bin/webapps/geoserver/WEB-INF/lib/marlin-0.9.3.jar -Dsun.java2d.renderer=org.marlin.pisces.MarlinRenderingEngine -Djetty.base=/vagrant/geoserver-2.20.2-bin -DGEOSERVER_DATA_DIR=/vagrant/geoserver-2.20.2-bin/data_dir -Djava.awt.headless=true -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -jar /vagrant/geoserver-2.20.2-bin/start.jar
I guess the same applies to other variables if the contain multiple arguments.
Would be great if setting multiple parameters in JAVA_OPTS will be supported again.
Björn
I believe a fix for that has already been done on the main branch:
https://github.com/geoserver/geoserver/pull/5415
Do you have time to issue a backport PR against 2.20.x?
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Hi Andrea
Sorry, I totally missed that with the mailing list search.
I created a pull request for 20.2.x:
https://github.com/geoserver/geoserver/pull/5623
Björn
Am Mi., 26. Jan. 2022 um 15:56 Uhr schrieb Andrea Aime <andrea.aime@anonymised.com>:
On Wed, Jan 26, 2022 at 2:20 PM Björn Küng <bjoern.kueng@anonymised.com> wrote:
Hello
2.19.x:
2.20.x:
  4. bin/startup.sh
Result:
Björn
Geoserver-devel mailing list
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
