--PROBLEM--
Geoserver displays broken images when trying to display a demo
It seems all WFS/WMS queries are broken
Examples:
http://69.90.210.52:8080/geoserver/data/generated/tiger_tiger_roads.html
--PROBLEM--
--VERSIONS--
linux:~ # java -version
java version "1.4.2_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_06-b03)
Java HotSpot(TM) Client VM (build 1.4.2_06-b03, mixed mode)
tomcat-5.5.12-0.noarch.rpm
tomcat-compat-5.5.12-0.noarch.rpm
Geoserver 1.3.0-r6
Linux linux 2.6.13-15.7-bigsmp #1 SMP Tue Nov 29 14:32:29 UTC 2005 i686 i686 i386 GNU/Linux
--VERSIONS--
--TOMCAT 5.5 LOGS--
linux:/opt/tomcat # tail /var/log/tomcat/*.log
==> /var/log/tomcat/admin.2006-01-03.log <==
==> /var/log/tomcat/admin.2006-01-04.log <==
==> /var/log/tomcat/catalina.2006-01-03.log <==
Jan 3, 2006 6:40:29 PM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Jan 3, 2006 6:40:29 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Jan 3, 2006 6:40:29 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/36 config=null
Jan 3, 2006 6:40:29 PM org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
Jan 3, 2006 6:40:29 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 2348 ms
==> /var/log/tomcat/catalina.2006-01-04.log <==
Jan 4, 2006 12:50:35 PM org.vfny.geoserver.ServiceException getXmlResponse
FINE: return wfs exception is <?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/ogc http://69.90.210.52:8080/geoserver/data/capabilities//wfs/1.0.0/OGC-exception.xsd">
<ServiceException>
javax.xml.transform.TransformerFactoryConfigurationError: Provider org.apache.xalan.processor.TransformerFactoryImpl not found </ServiceException>
</ServiceExceptionReport>
==> /var/log/tomcat/host-manager.2006-01-03.log <==
==> /var/log/tomcat/host-manager.2006-01-04.log <==
==> /var/log/tomcat/localhost.2006-01-03.log <==
Jan 3, 2006 6:40:28 PM org.apache.catalina.core.ApplicationContext log
INFO: ContextListener: contextInitialized()
INFO: SessionListener: contextInitialized()
Jan 3, 2006 6:40:29 PM org.apache.catalina.core.ApplicationContext log
INFO: org.apache.webapp.balancer.BalancerFilter: init(): ruleChain: [org.apache.webapp.balancer.RuleChain: [org.apache.webapp.balancer.rules.URLStringMatchRule: Target string: News / Redirect URL: http://www.cnn.com], [org.apache.webapp.balancer.rules.RequestParameterRule: Target param name: paramName / Target param value: paramValue / Redirect URL: http://www.yahoo.com], [org.apache.webapp.balancer.rules.AcceptEverythingRule: Redirect URL: http://jakarta.apache.org]]
==> /var/log/tomcat/localhost.2006-01-04.log <==
Jan 4, 2006 12:45:13 PM org.apache.catalina.core.ApplicationContext log
Jan 4, 2006 12:45:19 PM org.apache.catalina.core.ApplicationContext log
==> /var/log/tomcat/manager.2006-01-03.log <==
==> /var/log/tomcat/manager.2006-01-04.log <==
==> /var/log/tomcat/mapbuilder-log4j.log <==
--TOMCAT 5.5 LOGS--
