[Geoserver-devel] ?Bug...GML 2D/3D Point
Several weeks ago I post about my troubles obtaining the GML of a 3D Point object via a GetFeatures request such as the following:
http://localhost:8080/geoserver/wfs?request=GetFeature&typename=stvu:waypoints
One helpful individual suggested trying my request against a 2D point object to see if it worked (and validate my setup in general). He went on to state that if it does, I should submit a bug regarding the 3D point. So that's what I'm doing - submitting a bug. I just got around to setting up a 2D point object with a few thousands entries and they all return beautifully from my request. Additionally, the "generate bounding box" works perfectly on the 2D point but not at all on the 3D point.
Thanks for everyones help.
Hopefully this can be fixed soon and/or a work around can be thought up.
Much appreciated.
./dylan
Coul you add this to the geotools issue tracker?
http://jira.codehaus.org/secure/BrowseProject.jspa?id=10270
Mark it as a bug with PostGIS. This way we won't forget about it.
Chris
Quoting Eli Dylan Lorimer <e.d.lorimer@anonymised.com>:
up.
Much appreciated.
./dylan
This SF.Net email is sponsored by Oracle Space Sweepstakes
Want to be the first software developer in space?
Enter now for the Oracle Space Sweepstakes!
http://ads.osdn.com/?ad_id=7393&alloc_id=16281&op=click
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
