[Geoserver-devel] Bug in CQL filter parsing (definition query parsing?)
Hey all,
I ran into an issue when trying CQL filters against the ArcSDE module today. The issue is described in some depth here:
http://jira.codehaus.org/browse/GEOS-1979
along with the patch that attempted to fix it for me.
I'm not sure what the right answer is for this, or if it affects only the ArcSDE plugin. The symptoms were that feature creation from the supplied iterator were failing with "expected 2 properties but only found 1" or something like that.
Can someone take a look at the issue and see if my fix is appropriate and if other tests pass? I'm getting test failures in the SVG and KML rendering modules with the patch, but I'm not sure if they're extraneous/local issues. If it looks ok to someone who usually has passing tests, could such a kind person please apply it?
Thanks much in advance.
--saul
