Hi Andrea,
sure, here are the requests:
Scale: 1500:
http://xxx/geoserver/ows?SERVICE=WMS&REQUEST=GetLegendGraphic&VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20&LAYER=POINT_LAYER&SCALE=1500&EXCEPTIONS=application/json&BBOX=2567457.5047403597,5466971.456006,2567701.1052275603,5467324.67671244&SRS=EPSG:31466&FORMAT_OPTIONS=layout:legend&LEGEND_OPTIONS=countMatched:true;fontAntiAliasing:true;forceLabels:on&STYLE=Count_Test
returns in GetLegendGraphics-image: „maxScale (0)“
Scale: 2500:
http://xxx/geoserver/ows?SERVICE=WMS&REQUEST=GetLegendGraphic&VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20&LAYER=POINT_LAYER&SCALE=2500&EXCEPTIONS=application/json&BBOX=2567347.737958326,5466819.978984294,2567753.7387703275,5467408.680161696&SRS=EPSG:31466&FORMAT_OPTIONS=layout:legend&LEGEND_OPTIONS=countMatched:true;fontAntiAliasing:true;forceLabels:on&STYLE=Count_Test
returns in GetLegendGraphics-image: „minScale (261)“
Paul
Von: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] Im Auftrag von Andrea Aime
Gesendet: Donnerstag, 14. September 2017 11:48
An: Biskup, Paul <Paul.Biskup@anonymised.com>
Cc: geoserver-devel@anonymised.comsourceforge.net
Betreff: Re: [Geoserver-devel] Bug in GetLegendGraphic countMatched-feature when using MaxScaleDenominator in SLD
Hi Paul,
do you have the request too? If you have scale dependencies you need to also pass along a bbox and
a width/height so that the code can compute the target scale denominator
On Thu, Sep 14, 2017 at 11:29 AM, Biskup, Paul <Paul.Biskup@anonymised.com654…> wrote:
Hi GeoServer-team,
I have tested the new „return feature count“-feature in the GetLegendGraphic-request. It is a great feature, thank you for that!
But I think that there is a bug, if you have defined a „MaxScaleDenominator“ in your SLD-rule. If you specify the „MaxScaleDenominator“, the returned feature count in the generated legend is always „0“. The map-view for this SLD-rule (GetMap-request) works fine and displays the features correctly according to the scale.
The returned feature count works also correctly if you use the „minScaleDenominator“.
Is this a known bug?
Best regards,
Paul
P.S.: My SLD (maxScale2000:returns always feature count 0; minScale2000:returns correct feature count):
<?xml version="1.0" encoding="ISO-8859-1"?>
Count_Test
Count_Test
Count_Test
maxScale2000
maxScale2000
2000
circle
#00FFFF
1
10
minScale2000
minScale2000
2000
circle
#734C00
1
9
Geoserver-devel mailing list
Geoserver-devel@anonymised.comsourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
