[Geoserver-devel] Bug - Tiled WMS Layer and Watermarking
The Watermarks seems to disappear most of the times when using a tiled option with OpenLayers.
Thanks and Warm Regards
Debasish Sahu
Forgot to mention that I am using the current trunk build of GeoServer.
On Sun, May 31, 2009 at 1:01 PM, Debasish Sahu <debasish.sahu@anonymised.com> wrote:
Debasish Sahu
Debasish Sahu
Are you also using meta-tiling? (tiled=true&tilesOrigin=...)
Andrea Aime
OpenGeo - http://opengeo.org
I tried using the openlayers Layerpreview through the current trunk build of geoserver admin .
Are you also using meta-tiling? (tiled=true&tilesOrigin=…)
Andrea Aime
Debasish Sahu
Ok, in that case meta-tiling is used. I expect the watermark to appear
only in 1 tile out of 9 since the rendering is performed on a 3x3
block and then cut into 9 tiles. Is this what you're seeing?
Andrea Aime
Sometimes I see it … and most of the times it disappears !
Were you able to replicate at your end ?
block and then cut into 9 tiles. Is this what you’re seeing?
Andrea Aime
Debasish Sahu
Sometimes I see it .. and most of the times it disappears !
I'm just spending some hours on GeoTools today, so I did not
actually try. I'll do that tomorrow when I'm back on GeoServer.
Andrea Aime
I probably introduced this problem when reworking watermarks to use the
decoration code. I will take a look, should be a quick fix.
David Winslow
OpenGeo - http://opengeo.org/
Reproduced and fixed on my end. Please reopen
http://jira.codehaus.org/browse/GEOS-3107 if you still see this issue
with the next nightly.
David Winslow
David Winslow
> Cheers
> Andrea
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals. Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, &
iPhoneDevCamp as they present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com
Geoserver-devel mailing list
