Login fails from the layer preview page (in Jetty from Eclipse). I am pretty sure that this failed before the Spring 4 upgrade but I am sure that we want to fix this while fixing all the /login and /logout endpoints for Spring 4 compatibility:
HTTP ERROR 404
Problem accessing /geoserver/web/wicket/j_spring_security_check. Reason:
I’ve also noticed that the demo request page is not fully functional anymore,
try the following:
Choose a xml request (e.g., WFS something in xml post mode), run it (if using chrome the output will be garbled, chrome limitation, it cannot pretty print xml in the popup, that is known, use firefox instead)
Then choose another: the demo request xml is not populated anymore
HTTP ERROR 404
HTTP ERROR 404
Not Found
Powered by Jetty://
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more. http://pubads.g.doubleclick.net/gampad/clk?id=278785471&iu=/4140
