Folks,
today I tried:
mvn jetty:run -Pwps,rest
but Maven told me:
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/usr/var/projects/geoserver/geoserver/web/src/main/java/org/vfny/geoserver/action/SaveXMLAction.java:[66,32] cannot find symbol
symbol : method getRawData()
/usr/var/projects/geoserver/geoserver/web/src/main/java/org/vfny/geoserver/action/data/TypesEditorAction.java:[393,14] cannot find symbol
symbol : method setRegionateStrategy(java.lang.String)
location: class org.vfny.geoserver.config.FeatureTypeConfig
/usr/var/projects/geoserver/geoserver/web/src/main/java/org/vfny/geoserver/action/data/TypesEditorAction.java:[396,18] cannot find symbol
symbol : method setRegionateFeatureLimit(java.lang.Integer)
/usr/var/projects/geoserver/geoserver/web/src/main/java/org/vfny/geoserver/form/data/TypesEditorForm.java:[259,32] cannot find symbol
symbol : method getRegionateStrategy()
/usr/var/projects/geoserver/geoserver/web/src/main/java/org/vfny/geoserver/form/data/TypesEditorForm.java:[260,53] cannot find symbol
symbol : method getRegionateFeatureLimit()
/usr/var/projects/geoserver/geoserver/web/src/main/java/org/vfny/geoserver/action/UpdateGSAction.java:[73,18] cannot find symbol
Luca Morandini
www.lucamorandini.it
Luca Morandini ha scritto:
Folks,
today I tried:
but Maven told me:
I believe you did not build geoserver before running Jetty.
Can you do a mvn clean install before running mvn jetty:run in the
web module?
The build seems to be fine on the continuous build server:
http://gridlock.openplans.org:8080/hudson/
Luca Morandini
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-devel mailing list
!DSPAM:4022,48466d5e207721012714783!
Luca Morandini wrote:
Folks,
today I tried:
but Maven told me:
Solved: an "mvn clean" did the trick... I forgot about the vagaries of the Maven-way of building software.
Luca Morandini
