Hey folks,
Seems all the geoserver builds are broken with failure in the wps module. I have been able to confirm the failure locally. I wonder if this could be a result of some recent changes to the geotiff driver? I ask because the test failures seem to be resulting from unexpected values coming back from processes working on tif data. For example:
Test set: org.geoserver.wps.gs.RasterZonalStatsTest
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.682 sec <<< FAILURE!
testStatisticsTazDem(org.geoserver.wps.gs.RasterZonalStatsTest) Time elapsed: 1.413 sec <<< FAILURE!
junit.framework.ComparisonFailure: expected:<7[20]0> but was:<7[14]0>
at junit.framework.Assert.assertEquals(Assert.java:81)
at junit.framework.Assert.assertEquals(Assert.java:87)
at org.custommonkey.xmlunit.XMLAssert.assertXpathEvaluatesTo(XMLAssert.java:858)
at org.geoserver.wps.gs.RasterZonalStatsTest.testStatisticsTazDem(RasterZonalStatsTest.java:105)
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
On Fri, Aug 24, 2012 at 3:22 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hey folks,
It’s actually related to the WCS reprojection fixes I’ve made a few days ago, but they were not should up because
the build kept on failing on the security UI module.
Fixing this generated quite a cascading effect, I’ve been at it almost all day… should be fixed now, need confirmation
from the build server (the build worked fine locally)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
