I was trying to build trunk but...
cd src
svn up
mvn -version
Apache Maven 2.2.1 (rdebian-1)
Java version: 1.6.0_18
Java home: /usr/lib/jvm/jdk1.6.0_18/jre
Default locale: en_US, platform encoding: UTF-8
OS name: "linux" version: "2.6.32-24-generic" arch: "amd64" Family: "unix"
mvn clean
mvn install
[INFO] Building GeoServer
[INFO] task-segment: [install]
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Preparing source:jar
[INFO] Installing /usr/var/projects/geoserver/src/pom.xml to /home/lmorandini/.m2/repository/org/geoserver/geoserver/2.1-SNAPSHOT/geoserver-2.1-SNAPSHOT.pom
[INFO] Installing /usr/var/projects/geoserver/src/target/geoserver-2.1-SNAPSHOT-tests.jar to /home/lmorandini/.m2/repository/org/geoserver/geoserver/2.1-SNAPSHOT/geoserver-2.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Installing /usr/var/projects/geoserver/src/maven/pom.xml to /home/lmorandini/.m2/repository/org/geoserver/maven/2.1-SNAPSHOT/maven-2.1-SNAPSHOT.pom
[INFO] Installing /usr/var/projects/geoserver/src/maven/target/maven-2.1-SNAPSHOT-tests.jar to /home/lmorandini/.m2/repository/org/geoserver/maven/2.1-SNAPSHOT/maven-2.1-SNAPSHOT-tests.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] [plugin:descriptor {execution: default-descriptor}]
[WARNING] Using platform encoding (UTF-8 actually) to read mojo metadata, i.e. build is platform dependent!
[ERROR] BUILD ERROR
[INFO] The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match.
Embedded error: org.apache.maven.tools.plugin.scanner.MojoScanner.populatePluginDescriptor(Lorg/apache/maven/tools/plugin/PluginToolsRequest;)V
[INFO] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match.
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:719)
Any clue ?
Luca Morandini
[http://www.lucamorandini.it]
