[Geoserver-devel] Build Errors with Maven QuickStart
Hello all,
I've tried to walk through GeoServer Developer's Guide a few times now
and keep getting stuck at the same point. I'm on the Maven QuickStart
tutorial and I get build errors in two places. The first happens when
I'm installing GeoServer modules using the command "mvn install". I
get the following build error about wcs module:
[INFO] [compiler:compile]
[INFO] Compiling 53 source files to C:\geoserver_dev\src\wcs1_1\target\classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
C:\geoserver_dev\src\wcs1_1\src\main\java\org\geoserver\wcs\response\WCSCapsTransformer.java:[403,22
] cannot find symbol
symbol : method getNamespace()
location: interface net.opengis.wcs11.GetCapabilitiesType
C:\geoserver_dev\src\wcs1_1\src\main\java\org\geoserver\wcs\response\WCSCapsTransformer.java:[404,42
[INFO] Total time: 6 minutes 10 seconds
[INFO] Finished at: Sun Feb 15 15:56:03 CST 2009
[INFO] Final Memory: 34M/63M
The second build error happens when I try to run geoserver using the
command "mvn -o jetty:run". This tells me that certain .jar files are
missing. I've gone ahead and downloaded and installed two of them from
the listed repositories, but the third
(org.geoserver:gwc:jar:2.0-SNAPSHOT) doesn't exist on any of the
repositories. What should I be doing?
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver:wfs:jar:2.0-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geoserver
-DartifactId=wfs -Dversion=2.0-SNAPSHOT -Dpac
kaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geoserver -DartifactId=wfs
-Dversion=2.0-SNAPSHOT -Dpacka
ging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
        1) org.geoserver:web:jar:2.0-SNAPSHOT
        2) org.geoserver:wfs:jar:2.0-SNAPSHOT
2) org.geoserver:wms:jar:2.0-SNAPSHOT
-DartifactId=wms -Dversion=2.0-SNAPSHOT -Dpac
      mvn deploy:deploy-file -DgroupId=org.geoserver -DartifactId=wms
  Path to dependency:
3) org.geoserver:gwc:jar:2.0-SNAPSHOT
-DartifactId=gwc -Dversion=2.0-SNAPSHOT -Dpac
      mvn deploy:deploy-file -DgroupId=org.geoserver -DartifactId=gwc
  Path to dependency:
        2) org.geoserver:gwc:jar:2.0-SNAPSHOT
3 required artifacts are missing.
for artifact:
from the specified remote repositories:
  geotools (http://maven.geotools.fr/repository/),
  refractions (http://lists.refractions.net/m2/),
  mortbay (http://www.mortbay.org/maven2/release),
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2)
[INFO] Total time: 16 seconds
[INFO] Finished at: Sun Feb 15 16:06:48 CST 2009
[INFO] Final Memory: 18M/33M
Much help is needed and appreciated.
Thanks
Greg Corradini
Hi Greg,
This error is occurring b/c geoserver is being built against an older version of the geotools library. This is a problem with the geoserver pom.xml files, not your local setup.
If you are trying to build gs trunk from svn you can do an update. I have just committed a change to the root pom.xml which should enable you to grab the latest versions of the geotools libs.
You can also get around this by checking out the geotools source code (from svn.osgeo.org/geotools) and building it locally.
-Justin
Greg Corradini wrote:
Hello all,
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
  Path to dependency:
  Path to dependency:
for artifact:
Thanks
Greg Corradini
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hey Justin,
Thanks for the reply.
I'm going to build gs trunk with an update. I don't see any command
help in the gs docs for the update statement. I'll have to check maven
docs. I assume something like mvn -update. Any command-line pointers
On Sun, Feb 15, 2009 at 5:45 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Greg,
-Justin
Hello all,
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR] BUILD ERROR
[INFO]
Missing:
there:
Path to dependency:
there:
Path to dependency:
there:
Path to dependency:
for artifact:
[INFO]
[INFO]
[INFO]
Thanks
Greg Corradini
CA
Enterprise
participation
SFAD
Justin Deoliveira
Greg Corradini
ITS II, HPMS Coordinator
Minnesota Department of Transportation
395 John Ireland Blvd
St. Paul, MN 55155
651-366-3847
gregcorradini@anonymised.com
Greg Corradini ha scritto:
Hey Justin,
Maven is concerned only with the build, subversion is what deals
with the version control (it _is_ the version control).
Use: svn up
Andrea Aime
