See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-trunk/40/>
[...truncated 1547 lines...]
VAR_WCS_PARAMETER_VALUE_TEMP3:
VAR_WCS_PARAMETER_VALUE_TEMP4: /
VAR_WCS_PARAMETER_VALUE: 1
Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-post-xml-4 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-get-kvp-2 (wcs-1.0.0/d39e1898_1)...
Assertion: When a GetCoverage request is made with a valid RESPONSE_CRS, the server should return the requested content with this CRS.
VAR_WCS_TEMP_CRS: EPSG:4326
VAR_WCS_TEMP_RPCRS:
VAR_WCS_COVERAGE_1_CRS: EPSG:4326
VAR_WCS_COVERAGE_1_RESPONSE_CRS: EPSG:4326
VAR_WCS_FORMAT_1: GeoTIFF
VAR_WCS_COVERAGE_1_BBOX: -19.999999999999996,40.000000000019995,19.99999999998401,90.0
Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-get-kvp-2 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-get-kvp-3 (wcs-1.0.0/d39e1916_1)...
Assertion: When a GetCoverage request is made with an invalid RESPONSE_CRS, the server returns service exception.
Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-get-kvp-3 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-kvp-2 (wcs-1.0.0/d39e1935_1)...
VAR_WCS_TEMP_RPCRS:
Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-kvp-2 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-kvp-3 (wcs-1.0.0/d39e1956_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-kvp-3 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-2 (wcs-1.0.0/d39e1975_1)...
VAR_WCS_TEMP_RPCRS:
VAR_WCS_COVERAGE_1_POSITION_FIRST: -19.999999999999996 40.000000000019995
VAR_WCS_COVERAGE_1_POSITION_SECOND: 19.99999999998401 90.0
Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-2 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-3 (wcs-1.0.0/d39e1996_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-3 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-1 (wcs-1.0.0/d39e2013_1)...
Assertion: When a GetCoverage request is made without version, the server returns service exception.
VAR_WCS_TEMP_CRS:
VAR_WCS_COVERAGE_1_CRS: You_got_this_because_you_did_not_have_crs_included_in_your_first_domainSet_in_your_first_Coverage
VAR_WCS_COVERAGE_1_BBOX: ,
VAR_WCS_FORMAT_1:
Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-1 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-2 (wcs-1.0.0/d39e2026_1)...
Assertion: When a GetCoverage request is made with an invalid version, the server returns service exception.
Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-2 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-3 (wcs-1.0.0/d39e2043_1)...
Assertion: When a GetCoverage request is made with a version=1.0.0, the server should return the requested content (if other condition satisfied).
Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-3 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-1 (wcs-1.0.0/d39e2063_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-1 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-2 (wcs-1.0.0/d39e2084_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-2 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-3 (wcs-1.0.0/d39e2105_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-3 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-1 (wcs-1.0.0/d39e2126_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-1 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 (wcs-1.0.0/d39e2147_1)...
Assertion: When a GetCoverage request is made with a version an invalid version, the server returns service exception.
Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 (wcs-1.0.0/d39e2169_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_response-encoding-supportedFormats (wcs-1.0.0/d39e2380_1)...
Assertion: A valid getCoverage response is returned for each of the supportedFormats.
Test wcs1-0-0:getcoverage_operations-getcoverage_response-encoding-supportedFormats Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_response-multifile_payloads (wcs-1.0.0/d39e2393_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_response-multifile_payloads Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp (wcs-1.0.0/d39e2410_1)...
Assertion: When a GetCoverage request is made with a BBOX partly contained in the defined Bounding BOX, the server returns content.
VAR_WCS_COVERAGE_1_BBOX_OVERLAP: -21.999999999999996,38.000000000019995,18.99999999998401,89
Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp (wcs-1.0.0/d39e2430_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml (wcs-1.0.0/d39e2451_1)...
VAR_WCS_COVERAGE_1_BBOX_OVERLAP_POSITION_FIRST: -21.999999999999996 38.000000000019995
VAR_WCS_COVERAGE_1_BBOX_OVERLAP_POSITION_SECOND: 18.99999999998401 89
Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp (wcs-1.0.0/d39e2470_1)...
Assertion: When a GetCoverage request is made with a BBOX inside the defined Bounding BOX, the server returns content.
VAR_WCS_COVERAGE_1_BBOX_INSIDE: -18.999999999999996,41.000000000019995,18.99999999998401,89
Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp (wcs-1.0.0/d39e2490_1)...
Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml (wcs-1.0.0/d39e2511_1)...
VAR_WCS_COVERAGE_1_BBOX_INSIDE_POSITION_FIRST: -18.999999999999996 41.000000000019995
VAR_WCS_COVERAGE_1_BBOX_INSIDE_POSITION_SECOND: 18.99999999998401 89
Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-forbidden (wcs-1.0.0/d39e2531_1)...
Assertion: If the only interpolation method supported is "none", a GetCoverage request that uses resolution parameters to request a coverage that is not at the native resolution returns an exception.
VAR_WCS_TEMP_RPCRS:
VAR_WCS_TEMP_INTERPLATION_METHOD: nearest neighbor
VAR_WCS_INTERPLATION_METHOD: nearest neighbor
INTERPLATION_METHOD_COUNT: 3
Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-forbidden Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-forbidden (wcs-1.0.0/d39e2549_1)...
Assertion: If the only interpolation method supported is "none", a GetCoverage request that uses height and width parameters to request a coverage that is not at the native resolution returns an exception.
VAR_WCS_TEMP_RPCRS:
Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-forbidden Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-resolutions (wcs-1.0.0/d39e2567_1)...
Assertion: A coverage request using RESX, RESY, RESZ and INTERPOLATION=none raises an exception.
Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-resolutions Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-response_crs (wcs-1.0.0/d39e2585_1)...
Assertion: A coverage request using RESPONSE_CRS and INTERPOLATION=none raises an exception.
VAR_WCS_TEMP_RPCRS:
Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-response_crs Passed
Testing wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method (wcs-1.0.0/d39e2603_1)...
Assertion: For each of the advertised interpolation methods, the server returns content.
VAR_WCS_TEMP_RPCRS:
Test wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method Passed
Test wcs1-0-0:main Failed (Inherited failure)
Suite wcs1-0-0:main_wcs1-0-0 Failed
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-trunk/ws/tools>
cp target/sessions/session.xml.wcs-1.0.0 users/geoserver/wcs-1.0.0/session.xml
Test wcs1-0-0:main (wcs-1.0.0) Failed (Inherited Failure)
Test wcs1-0-0:basic_service_elements-general_http_request_rules-4 (wcs-1.0.0/d39e576_1) Failed
Test wcs1-0-0:basic_service_elements-general_http_request_rules-5 (wcs-1.0.0/d39e585_1) Failed
Test wcs1-0-0:describecoverage_operations-describecoverage_request-get-kvp-5 (wcs-1.0.0/d39e666_1) Failed
Test wcs1-0-0:describecoverage_operations-describecoverage_request-post-kvp-5 (wcs-1.0.0/d39e754_1) Failed
Test wcs1-0-0:describecoverage_operations-describecoverage_request-post-xml-5 (wcs-1.0.0/d39e812_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-get-kvp-3 (wcs-1.0.0/d39e895_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-get-kvp-5 (wcs-1.0.0/d39e919_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-get-kvp-6 (wcs-1.0.0/d39e928_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-get-kvp-7 (wcs-1.0.0/d39e937_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-kvp-3 (wcs-1.0.0/d39e973_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-kvp-5 (wcs-1.0.0/d39e999_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-kvp-6 (wcs-1.0.0/d39e1011_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-kvp-7 (wcs-1.0.0/d39e1024_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-xml-3 (wcs-1.0.0/d39e1056_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-xml-5 (wcs-1.0.0/d39e1078_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-xml-6 (wcs-1.0.0/d39e1089_1) Failed
Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-xml-7 (wcs-1.0.0/d39e1099_1) Failed
RETURN=1
Pinging GeoServer at http://localhost:11010/geoserver
curl: (7) couldn't connect to host
GeoServer is offline
