See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1-trunk/1/>
[...truncated 2222 lines...]
Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Field_Identifier_And_InterpolationMethod (wcs-1.1.1/d39e339_1/d39e11963_1)...
Assertion: Verify that when a GetCoverage request using KVP with a semicolon
between Field Identifier And InterpolationMethod is submitted,
the response is an exception.
Using KVP encoding.
A DescribeCoverage MinimalRequest initial test case failed. The error is Required paramer, identifiers, missing
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Field_Identifier_And_InterpolationMethod Failed
Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Identifiers (wcs-1.1.1/d39e339_1/d39e12009_1)...
between Axis Identifiers is submitted, the response is an exception.
Using KVP encoding.
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Identifiers Failed
Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Keys (wcs-1.1.1/d39e339_1/d39e12055_1)...
between Axis Keys is submitted, the response is an exception.
Using KVP encoding.
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Keys Failed
Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Identifier (wcs-1.1.1/d39e339_1/d39e12101_1)...
Assertion: Verify that when a GetCoverage request using KVP with a missing
opening square bracket before the axis identifier is submitted,
Using KVP encoding.
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Identifier Failed
Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Key (wcs-1.1.1/d39e339_1/d39e12147_1)...
opening square bracket before the axis key is submitted,
Using KVP encoding.
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Key Failed
Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Closing_Square_Bracket (wcs-1.1.1/d39e339_1/d39e12193_1)...
closing square bracket is submitted, the response is an exception.
Using KVP encoding.
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Closing_Square_Bracket Failed
Testing wcs:GetCoverage_Formats (wcs-1.1.1/d39e339_1/d39e12239_1)...
Assertion: Verify that when a GetCoverage request with a format
is submitted, the response is not an exception.
Using KVP encoding.
Test wcs:GetCoverage_Formats Failed
Testing wcs:GetCoverage_Formats (wcs-1.1.1/d39e339_1/d39e12263_1)...
Using XML encoding.
A DescribeCoverage MinimalRequest initial test case failed. The error is Parsing failed, the xml request is most probably not compliant to the wcs schema
cvc-pattern-valid: Value '' is not facet-valid with respect to pattern '.+' for type 'IdentifierType'.
Testing wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d39e339_1/d39e12309_1)...
Assertion: Verify that when a GetCoverage request with a bogus format
Using KVP encoding.
Test wcs:GetCoverage_Bogus_Format Failed
Testing wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d39e339_1/d39e12333_1)...
Using XML encoding.
Testing wcs:GetCoverage_Empty_Format (wcs-1.1.1/d39e339_1/d39e12379_1)...
Assertion: Verify that when a GetCoverage request with an empty string for
the format is submitted, the response is an exception.
Using KVP encoding.
Test wcs:GetCoverage_Empty_Format Failed
Testing wcs:GetCoverage_Empty_Format (wcs-1.1.1/d39e339_1/d39e12403_1)...
Using XML encoding.
Testing wcs:GetCoverage_Missing_Format (wcs-1.1.1/d39e339_1/d39e12449_1)...
Assertion: Verify that when a GetCoverage request with the format missing
Using KVP encoding.
Test wcs:GetCoverage_Missing_Format Failed
Testing wcs:GetCoverage_Missing_Format (wcs-1.1.1/d39e339_1/d39e12473_1)...
Using XML encoding.
Testing wcs:GetCoverage_Store_True (wcs-1.1.1/d39e339_1/d39e12519_1)...
Assertion: Verify that when a GetCoverage request with a store parameter set
to true is submitted, the response is an exception or not depending
on the capabilities.
Using KVP encoding.
Test wcs:GetCoverage_Store_True Failed
Testing wcs:GetCoverage_Store_True (wcs-1.1.1/d39e339_1/d39e12544_1)...
Using XML encoding.
Testing wcs:GetCoverage_Store_False (wcs-1.1.1/d39e339_1/d39e12590_1)...
set to false is submitted, the response is not an exception.
Using KVP encoding.
Test wcs:GetCoverage_Store_False Failed
Testing wcs:GetCoverage_Store_False (wcs-1.1.1/d39e339_1/d39e12614_1)...
Using XML encoding.
Testing wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d39e339_1/d39e12660_1)...
set to a bogus value is submitted, the response is an exception.
Using KVP encoding.
Test wcs:GetCoverage_Store_Bogus Failed
Testing wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d39e339_1/d39e12684_1)...
Using XML encoding.
Test wcs:GetCoverage-main Failed (Inherited failure)
Test wcs:Main Failed (Inherited failure)
Suite wcs:suite Failed
Test wcs:Main (wcs-1.1.1) Failed (Inherited Failure)
Test wcs:GetCapabilities-main (wcs-1.1.1/d39e329_1) Failed (Inherited Failure)
Test wcs:GetCapabilities_Sections_ServiceIdentification (wcs-1.1.1/d39e329_1/d39e719_1) Failed
Test wcs:GetCapabilities_Sections_ServiceIdentification (wcs-1.1.1/d39e329_1/d39e746_1) Failed
Test wcs:GetCapabilities_Sections_Contents (wcs-1.1.1/d39e329_1/d39e947_1) Failed
Test wcs:GetCapabilities_Sections_Contents (wcs-1.1.1/d39e329_1/d39e974_1) Failed
Test wcs:GetCapabilities_UpdateSequence_Lowest_Value (wcs-1.1.1/d39e329_1/d39e1861_1) Failed
Test wcs:GetCapabilities_UpdateSequence_Lowest_Value (wcs-1.1.1/d39e329_1/d39e1888_1) Failed
Test wcs:GetCapabilities_Response_ServiceIdentification (wcs-1.1.1/d39e329_1/d39e2166_1) Failed
Test wcs:GetCapabilities_Response_ServiceProvider (wcs-1.1.1/d39e329_1/d39e2206_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata (wcs-1.1.1/d39e329_1/d39e2246_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Required_Attributes (wcs-1.1.1/d39e329_1/d39e2286_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Post_Encoding (wcs-1.1.1/d39e329_1/d39e2326_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Post_Multiple_Connect_Points (wcs-1.1.1/d39e329_1/d39e2366_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Store_Parameter (wcs-1.1.1/d39e329_1/d39e2406_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents (wcs-1.1.1/d39e329_1/d39e2446_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary (wcs-1.1.1/d39e329_1/d39e2486_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_SupportedCRS (wcs-1.1.1/d39e329_1/d39e2526_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_SupportedFormat (wcs-1.1.1/d39e329_1/d39e2566_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Title (wcs-1.1.1/d39e329_1/d39e2606_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Abstract (wcs-1.1.1/d39e329_1/d39e2646_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_SupportedFormat (wcs-1.1.1/d39e329_1/d39e2686_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_SupportedCRS (wcs-1.1.1/d39e329_1/d39e2726_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Identifier (wcs-1.1.1/d39e329_1/d39e2766_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Identifier_XML (wcs-1.1.1/d39e329_1/d39e2806_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_SupportedFormat_XML (wcs-1.1.1/d39e329_1/d39e2846_1) Failed
Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Identifier_Unique (wcs-1.1.1/d39e329_1/d39e2886_1) Failed
Test wcs:DescribeCoverage-main (wcs-1.1.1/d39e334_1) Failed (Inherited Failure)
Test wcs:DescribeCoverage_Response_InterpolationMethods (wcs-1.1.1/d39e334_1/d39e7334_1) Failed
Test wcs:DescribeCoverage_Response_InterpolationMethods (wcs-1.1.1/d39e334_1/d39e7358_1) Failed
Test wcs:DescribeCoverage_Response_Identifier_XML (wcs-1.1.1/d39e334_1/d39e7404_1) Failed
Test wcs:DescribeCoverage_Response_Identifier_XML (wcs-1.1.1/d39e334_1/d39e7428_1) Failed
Test wcs:DescribeCoverage_Response_SupportedFormat_XML (wcs-1.1.1/d39e334_1/d39e7474_1) Failed
Test wcs:DescribeCoverage_Response_SupportedFormat_XML (wcs-1.1.1/d39e334_1/d39e7498_1) Failed
Test wcs:DescribeCoverage_Response_FieldIdentifier_XML (wcs-1.1.1/d39e334_1/d39e7544_1) Failed
Test wcs:DescribeCoverage_Response_FieldIdentifier_XML (wcs-1.1.1/d39e334_1/d39e7568_1) Failed
Test wcs:DescribeCoverage_Response_InterpolationMethod_XML (wcs-1.1.1/d39e334_1/d39e7614_1) Failed
Test wcs:DescribeCoverage_Response_InterpolationMethod_XML (wcs-1.1.1/d39e334_1/d39e7639_1) Failed
Test wcs:DescribeCoverage_Response_AxisIdentifier_XML (wcs-1.1.1/d39e334_1/d39e7685_1) Failed
Test wcs:DescribeCoverage_Response_AxisIdentifier_XML (wcs-1.1.1/d39e334_1/d39e7709_1) Failed
Test wcs:DescribeCoverage_Response_AxisKey_XML (wcs-1.1.1/d39e334_1/d39e7755_1) Failed
Test wcs:DescribeCoverage_Response_AxisKey_XML (wcs-1.1.1/d39e334_1/d39e7779_1) Failed
Test wcs:GetCoverage-main (wcs-1.1.1/d39e339_1) Failed (Inherited Failure)
Test wcs:GetCoverage_MinimalRequest (wcs-1.1.1/d39e339_1/d39e9272_1) Failed
Test wcs:GetCoverage_MinimalRequest (wcs-1.1.1/d39e339_1/d39e9296_1) Failed
Test wcs:GetCoverage_MissingIdentifier (wcs-1.1.1/d39e339_1/d39e9342_1) Failed
Test wcs:GetCoverage_MissingIdentifier (wcs-1.1.1/d39e339_1/d39e9366_1) Failed
Test wcs:GetCoverage_EmptyIdentifier (wcs-1.1.1/d39e339_1/d39e9412_1) Failed
Test wcs:GetCoverage_EmptyIdentifier (wcs-1.1.1/d39e339_1/d39e9436_1) Failed
Test wcs:GetCoverage_BogusIdentifier (wcs-1.1.1/d39e339_1/d39e9482_1) Failed
Test wcs:GetCoverage_BogusIdentifier (wcs-1.1.1/d39e339_1/d39e9506_1) Failed
Test wcs:GetCoverage_MissingBoundingBox (wcs-1.1.1/d39e339_1/d39e9552_1) Failed
Test wcs:GetCoverage_MissingBoundingBox (wcs-1.1.1/d39e339_1/d39e9576_1) Failed
Test wcs:GetCoverage_SurroundingBoundingBox (wcs-1.1.1/d39e339_1/d39e9622_1) Failed
Test wcs:GetCoverage_SurroundingBoundingBox (wcs-1.1.1/d39e339_1/d39e9647_1) Failed
Test wcs:GetCoverage_InsideBoundingBox (wcs-1.1.1/d39e339_1/d39e9693_1) Failed
Test wcs:GetCoverage_InsideBoundingBox (wcs-1.1.1/d39e339_1/d39e9717_1) Failed
Test wcs:GetCoverage_OverlappingBoundingBox (wcs-1.1.1/d39e339_1/d39e9763_1) Failed
Test wcs:GetCoverage_OverlappingBoundingBox (wcs-1.1.1/d39e339_1/d39e9787_1) Failed
Test wcs:GetCoverage_BoundingBox_OutOfRangeCoordinates (wcs-1.1.1/d39e339_1/d39e9833_1) Failed
Test wcs:GetCoverage_BoundingBox_OutOfRangeCoordinates (wcs-1.1.1/d39e339_1/d39e9857_1) Failed
Test wcs:GetCoverage_OutsideBoundingBox (wcs-1.1.1/d39e339_1/d39e9903_1) Failed
Test wcs:GetCoverage_OutsideBoundingBox (wcs-1.1.1/d39e339_1/d39e9927_1) Failed
Test wcs:GetCoverage_AntimeridianBoundingBox (wcs-1.1.1/d39e339_1/d39e9973_1) Failed
Test wcs:GetCoverage_AntimeridianBoundingBox (wcs-1.1.1/d39e339_1/d39e9997_1) Failed
Test wcs:GetCoverage_RangeSubset_Identifier (wcs-1.1.1/d39e339_1/d39e10862_1) Failed
Test wcs:GetCoverage_RangeSubset_Identifier (wcs-1.1.1/d39e339_1/d39e10886_1) Failed
Test wcs:GetCoverage_RangeSubset_Repeated_Identifiers (wcs-1.1.1/d39e339_1/d39e11035_1) Failed
Test wcs:GetCoverage_RangeSubset_Repeated_Identifiers (wcs-1.1.1/d39e339_1/d39e11059_1) Failed
Test wcs:GetCoverage_RangeSubset_Bogus_Identifier (wcs-1.1.1/d39e339_1/d39e11105_1) Failed
Test wcs:GetCoverage_RangeSubset_Bogus_Identifier (wcs-1.1.1/d39e339_1/d39e11129_1) Failed
Test wcs:GetCoverage_RangeSubset_Valid_With_Bogus_Identifiers (wcs-1.1.1/d39e339_1/d39e11175_1) Failed
Test wcs:GetCoverage_RangeSubset_Valid_With_Bogus_Identifiers (wcs-1.1.1/d39e339_1/d39e11199_1) Failed
Test wcs:GetCoverage_RangeSubset_InterpolationMethod (wcs-1.1.1/d39e339_1/d39e11245_1) Failed
Test wcs:GetCoverage_RangeSubset_InterpolationMethod (wcs-1.1.1/d39e339_1/d39e11269_1) Failed
Test wcs:GetCoverage_RangeSubset_InterpolationMethod_Missing (wcs-1.1.1/d39e339_1/d39e11315_1) Failed
Test wcs:GetCoverage_RangeSubset_InterpolationMethod_Missing (wcs-1.1.1/d39e339_1/d39e11339_1) Failed
Test wcs:GetCoverage_RangeSubset_InterpolationMethod_Bogus (wcs-1.1.1/d39e339_1/d39e11385_1) Failed
Test wcs:GetCoverage_RangeSubset_InterpolationMethod_Bogus (wcs-1.1.1/d39e339_1/d39e11410_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_One_Key (wcs-1.1.1/d39e339_1/d39e11456_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_One_Key (wcs-1.1.1/d39e339_1/d39e11480_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Some_Keys (wcs-1.1.1/d39e339_1/d39e11526_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Some_Keys (wcs-1.1.1/d39e339_1/d39e11550_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_All_Keys (wcs-1.1.1/d39e339_1/d39e11596_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_All_Keys (wcs-1.1.1/d39e339_1/d39e11620_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_No_Key (wcs-1.1.1/d39e339_1/d39e11666_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_No_Key (wcs-1.1.1/d39e339_1/d39e11690_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Bogus_Key (wcs-1.1.1/d39e339_1/d39e11736_1) Failed
Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Bogus_Key (wcs-1.1.1/d39e339_1/d39e11760_1) Failed
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Field_Identifier_And_InterpolationMethod (wcs-1.1.1/d39e339_1/d39e11963_1) Failed
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Identifiers (wcs-1.1.1/d39e339_1/d39e12009_1) Failed
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Keys (wcs-1.1.1/d39e339_1/d39e12055_1) Failed
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Identifier (wcs-1.1.1/d39e339_1/d39e12101_1) Failed
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Key (wcs-1.1.1/d39e339_1/d39e12147_1) Failed
Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Closing_Square_Bracket (wcs-1.1.1/d39e339_1/d39e12193_1) Failed
Test wcs:GetCoverage_Formats (wcs-1.1.1/d39e339_1/d39e12239_1) Failed
Test wcs:GetCoverage_Formats (wcs-1.1.1/d39e339_1/d39e12263_1) Failed
Test wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d39e339_1/d39e12309_1) Failed
Test wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d39e339_1/d39e12333_1) Failed
Test wcs:GetCoverage_Empty_Format (wcs-1.1.1/d39e339_1/d39e12379_1) Failed
Test wcs:GetCoverage_Empty_Format (wcs-1.1.1/d39e339_1/d39e12403_1) Failed
Test wcs:GetCoverage_Missing_Format (wcs-1.1.1/d39e339_1/d39e12449_1) Failed
Test wcs:GetCoverage_Missing_Format (wcs-1.1.1/d39e339_1/d39e12473_1) Failed
Test wcs:GetCoverage_Store_True (wcs-1.1.1/d39e339_1/d39e12519_1) Failed
Test wcs:GetCoverage_Store_True (wcs-1.1.1/d39e339_1/d39e12544_1) Failed
Test wcs:GetCoverage_Store_False (wcs-1.1.1/d39e339_1/d39e12590_1) Failed
Test wcs:GetCoverage_Store_False (wcs-1.1.1/d39e339_1/d39e12614_1) Failed
Test wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d39e339_1/d39e12660_1) Failed
Test wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d39e339_1/d39e12684_1) Failed
RETURN=1
Pinging GeoServer at http://localhost:11010/geoserver
curl: (7) couldn't connect to host
GeoServer is offline
