See <http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/152/>
[...truncated 980 lines...]
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
CREATE TABLE
UPDATE 68
UPDATE 68
NOTICE: ALTER TABLE will create implicit sequence "Deletes_pkey_seq" for serial column "Deletes.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Deletes_pkey" for table "Deletes"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Fifteen_pkey_seq" for serial column "Fifteen.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Fifteen_pkey" for table "Fifteen"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Inserts_pkey_seq" for serial column "Inserts.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Inserts_pkey" for table "Inserts"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Lines_pkey_seq" for serial column "Lines.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Lines_pkey" for table "Lines"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Locks_pkey_seq" for serial column "Locks.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Locks_pkey" for table "Locks"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "MLines_pkey_seq" for serial column "MLines.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "MLines_pkey" for table "MLines"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "MPoints_pkey_seq" for serial column "MPoints.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "MPoints_pkey" for table "MPoints"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "MPolygons_pkey_seq" for serial column "MPolygons.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "MPolygons_pkey" for table "MPolygons"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Nulls_pkey_seq" for serial column "Nulls.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Nulls_pkey" for table "Nulls"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Other_pkey_seq" for serial column "Other.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Other_pkey" for table "Other"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Points_pkey_seq" for serial column "Points.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Points_pkey" for table "Points"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Polygons_pkey_seq" for serial column "Polygons.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Polygons_pkey" for table "Polygons"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Seven_pkey_seq" for serial column "Seven.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Seven_pkey" for table "Seven"
ALTER TABLE
ALTER TABLE
NOTICE: ALTER TABLE will create implicit sequence "Updates_pkey_seq" for serial column "Updates.pkey"
ALTER TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index "Updates_pkey" for table "Updates"
ALTER TABLE
ALTER TABLE
Pinging GeoServer at http://localhost:11010/geoserver
curl: (7) couldn't connect to host
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
108 1296 108 1296 0 0 26941 0 --:--:-- --:--:-- --:--:-- 27574
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"/>
<title>Error 404 NOT_FOUND</title>
</head>
<body>
<h2>HTTP ERROR: 404</h2><pre>NOT_FOUND</pre>
<p>RequestURI=/geoserver</p>
<p><i><small><a href="http://jetty.mortbay.org">Powered by jetty://</a></small></i></p>
</body>
</html>
GeoServer is online
Testing suite wfs:main_wfs...
Testing wfs:main (wfs-1.0.0)...
Assertion: This WFS is valid
Checking for <http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/ws/tools/wfs-1.0.0.xml>
java.io.FileNotFoundException: http://localhost:11010/geoserver/wfs?request=getcapabilities&service=wfs&version=1.0.0
Testing wfs:test1.0.0-basic-getcapabilities-get-1 (wfs-1.0.0/d39e825_1)...
Assertion: When a wfs:GetCapabilities request is made for a version number that the server supports, the result document must be a wfs:WFS_Capabilities with the version number equal to the version number in the request.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-1.test;> Line#: 44; Column#: -1
Test wfs:test1.0.0-basic-getcapabilities-get-1 Failed
Testing wfs:test1.0.0-basic-getcapabilities-get-2 (wfs-1.0.0/d39e830_1)...
Assertion: When a wfs:GetCapabilities request is made for a version number that is greater than the version the server supports, the result document must be a wfs:WFS_Capabilities with the version number equal to the highest version number that the server supports which is less than the requested version number.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=99.99.99&request=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-2.test;> Line#: 43; Column#: -1
Test wfs:test1.0.0-basic-getcapabilities-get-2 Failed
Testing wfs:test1.0.0-basic-getcapabilities-get-3 (wfs-1.0.0/d39e835_1)...
Assertion: When a wfs:GetCapabilities request is made for a version number that is less than the version the server supports, the result document must be a wfs:WFS_Capabilities with the version number equal to the lowest version number that the server supports which is greater than the requested version number.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=0.99.99&request=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-3.test;> Line#: 43; Column#: -1
Test wfs:test1.0.0-basic-getcapabilities-get-3 Failed
Testing wfs:test1.0.0-basic-getcapabilities-get-4 (wfs-1.0.0/d39e840_1)...
Assertion: When a wfs:GetCapabilities request is made without specifying a version number, the result document must be a wfs:WFS_Capabilities with the version number equal to the highest version number that it supports.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&request=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-4.test;> Line#: 42; Column#: -1
Test wfs:test1.0.0-basic-getcapabilities-get-4 Failed
Testing wfs:test1.0.0-basic-getcapabilities-get-5 (wfs-1.0.0/d39e845_1)...
Assertion: When a GetCapabilities request is made against basic WFS, the reponse cabilities document must define capabilities entries for the request GetCapabilities for HTTP GET, DescribeFeatureType for HTTP GET or POST and GetFeature for HTTP GET or POST.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-5.test;> Line#: 44; Column#: -1
Test wfs:test1.0.0-basic-getcapabilities-get-5 Failed
Testing wfs:test1.0.0-basic-getcapabilities-get-6 (wfs-1.0.0/d39e851_1)...
Assertion: When a wfs:GetCapabilities request is made, the result document must contain a schema description language of XMLSCHEMA for DescribeFeatureType.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-6.test;> Line#: 44; Column#: -1
Test wfs:test1.0.0-basic-getcapabilities-get-6 Failed
Testing wfs:test1.0.0-basic-getcapabilities-get-7 (wfs-1.0.0/d39e856_1)...
Assertion: When a wfs:GetCapabilities request is made, the result document must contain a result format of GML2 for GetFeature.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-7.test;> Line#: 44; Column#: -1
Test wfs:test1.0.0-basic-getcapabilities-get-7 Failed
Testing wfs:test1.0.0-basic-getcapabilities-get-8 (wfs-1.0.0/d39e861_1)...
Assertion: When a wfs:GetCapabilities request is made to a basic WFS, the result document must define the Query operation either globally or for at least one feature type.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?service=WFS&version=1.0.0&request=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wfs-1.0-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwfs-1.0.0~2Fctl~2Fwfs.xml/wfs$test1.0.0-basic-getcapabilities-get-8.test;> Line#: 44; Column#: -1
Test wfs:test1.0.0-basic-getcapabilities-get-8 Failed
Test wfs:main Failed (Inherited failure)
Suite wfs:main_wfs Failed
Test wfs:main (wfs-1.0.0) Failed (Inherited Failure)
Test wfs:test1.0.0-basic-getcapabilities-get-1 (wfs-1.0.0/d39e825_1) Failed
Test wfs:test1.0.0-basic-getcapabilities-get-2 (wfs-1.0.0/d39e830_1) Failed
Test wfs:test1.0.0-basic-getcapabilities-get-3 (wfs-1.0.0/d39e835_1) Failed
Test wfs:test1.0.0-basic-getcapabilities-get-4 (wfs-1.0.0/d39e840_1) Failed
Test wfs:test1.0.0-basic-getcapabilities-get-5 (wfs-1.0.0/d39e845_1) Failed
Test wfs:test1.0.0-basic-getcapabilities-get-6 (wfs-1.0.0/d39e851_1) Failed
Test wfs:test1.0.0-basic-getcapabilities-get-7 (wfs-1.0.0/d39e856_1) Failed
Test wfs:test1.0.0-basic-getcapabilities-get-8 (wfs-1.0.0/d39e861_1) Failed
RETURN=1
Process leaked file descriptors. See http://hudson.gotdns.com/wiki/display/HUDSON/Spawning+processes+from+build for more information
GeoServer is offline
