See <http://hudson.opengeo.org/hudson/job/cite-wfs-1.1/300/>
[...truncated 3748 lines...]
Assertion: Validate an XML instance against a Schematron schema using the given phase.
Test ctl:SchematronValidatingParser Passed
Test wfs:wfs-1.1.0-Transaction-tc12.1 Passed
Testing wfs:wfs-1.1.0-Transaction-tc13.1 (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26592_1)...
Assertion:
In response to a valid delete request, all matching features shall be deleted.
Testing wfs:GetFeatureById-KVP (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26592_1/d39e29266_1)...
Assertion: Attempts to fetch a feature by identifier using the GetFeature/GET binding.
Validation warning:
SchemaLocation: schemaLocation value = 'http://www.opengis.net/wfs http://localhost:11010/geoserver/schemas/wfs/1.1.0/wfs.xsd http://localhost:11010/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=sf%3APrimitiveGeoFeature’ must have even number of URI's.
1 warning detected.
Test wfs:GetFeatureById-KVP Passed
Testing wfs:GetFeatureById-KVP (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26592_1/d39e29276_1)...
Validation warning:
1 warning detected.
Testing wfs:GetFeatureById-KVP (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26592_1/d39e29285_1)...
Validation warning:
SchemaLocation: schemaLocation value = 'http://www.opengis.net/wfs http://localhost:11010/geoserver/schemas/wfs/1.1.0/wfs.xsd http://localhost:11010/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=sf%3AEntit�G�n�rique’ must have even number of URI's.
1 warning detected.
Test wfs:wfs-1.1.0-Transaction-tc13.1 Passed
Testing wfs:run-Transaction-Cleanup (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1)...
Assertion: Run test group for cleaning up (deleting) the features inserted by the Transactions.
Testing wfs:delete-test-data (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1)...
Assertion: Deletes the test data used in transactions during the test run.
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25292_1)...
Assertion:
Deletes a feature by typename and gml:name.
Test wfs:delete-feature Passed
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25301_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25310_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25319_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25328_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25338_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25347_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25356_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25365_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25374_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25383_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25393_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25402_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25411_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25420_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25429_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25438_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25448_1)...
Assertion:
Testing wfs:delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25457_1)...
Assertion:
Testing wfs:filter-delete-feature (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31854_1/d39e26617_1/d39e25265_1/d39e25500_1)...
Assertion:
Deletes a feature by by a manual filter.
Test wfs:filter-delete-feature Passed
Test wfs:delete-test-data Passed
Test wfs:run-Transaction-Cleanup Passed
Test wfs:run-Transaction-POST Passed
LockFeature using the POST method is implemented.
Testing wfs:run-LockFeature-POST (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1)...
Assertion: Run test group for LockFeature requests using the POST method
Testing wfs:LockFeature-expiry (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29849_1)...
Assertion: After a LockFeature request with an expiry attribute is submitted and the time expires, the lock is released.
Unable to acquire lock on PrimitiveGeoFeature.8
Test wfs:LockFeature-expiry Passed
Testing wfs:LockFeature-some-features (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29854_1)...
Assertion: In response to a LockFeature request that includes some locked and some unlocked feature identifiers and lockAction=SOME, the response is a 'WFS_LockFeatureResponse' element that lists the previously unlocked feature ids in the 'FeaturesLocked' element and the previously locked feature ids in the 'FeaturesNotLocked' element. The previously unlocked features are locked.
Unable to acquire lock on PrimitiveGeoFeature.3
Test wfs:LockFeature-some-features Passed
Testing wfs:LockFeature-all-features (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29859_1)...
Assertion: The response to a LockFeature request includes the identifiers of features that were locked.
Test wfs:LockFeature-all-features Passed
Testing wfs:LockFeature-identifiers-none (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29864_1)...
Assertion: In response to a LockFeature request that contains a filter that doesn't match any features, the response is a 'WFS_LockFeatureResponse' document that contains a value for the lockId attribute but contains neither a 'FeaturesLocked' element nor a 'FeatureNotLocked' element.
Test wfs:LockFeature-identifiers-none Passed
Testing wfs:LockFeature-invalid-request (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29869_1)...
Assertion: An invalid LockFeature request results in an exception.
Test wfs:LockFeature-invalid-request Passed
Target endpoint is http://localhost:11010/geoserver/wfs
Testing wfs:wfs-1.1.0-LockFeature-tc1.1 (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29899_1)...
Assertion:
The response to a LockFeature request that specifies lockAction="ALL" must
include a response that identifies all locked features. If any candidate
features cannot be locked, then no feature shall be locked and an exception
report is returned.
Testing ctl:SchematronValidatingParser (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29899_1/d39e30105_1)...
Testing wfs:GetFeatureById-KVP (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29899_1/d39e30142_1)...
Validation warning:
1 warning detected.
Testing wfs:GetFeatureByName (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29899_1/d39e30208_1)...
Assertion: Attempt to fetch a feature by name using the GetFeature/POST binding.
Test wfs:GetFeatureByName Passed
Test wfs:wfs-1.1.0-LockFeature-tc1.1 Passed
Testing wfs:wfs-1.1.0-LockFeature-tc2.1 (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29913_1)...
Assertion:
The response to a Transaction request that specifies an invalid LockId
value must include an exception report.
Testing ctl:SchematronValidatingParser (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29913_1/d39e30297_1)...
Test wfs:wfs-1.1.0-LockFeature-tc2.1 Passed
Testing wfs:wfs-1.1.0-LockFeature-tc3.1 (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29918_1)...
Assertion:
In response to a Transaction request that specifies releaseAction="SOME",
only modified features in the lock set shall be unlocked.
Testing wfs:GetFeatureByName (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29918_1/d39e30571_1)...
Testing ctl:SchematronValidatingParser (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31871_1/d39e29918_1/d39e30632_1)...
Test wfs:wfs-1.1.0-LockFeature-tc3.1 Passed
Test wfs:run-LockFeature-POST Passed
GetFeatureWithLock using the POST method is implemented.
Testing wfs:run-GetFeatureWithLock-POST (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31884_1)...
Assertion: Run test group for GetFeatureWithLock requests using the POST method
Testing wfs:GetFeatureWithLock-Xlink (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31884_1/d39e31244_1)...
Assertion: Execute WFS transaction with XlinkPropertyName and test for exception.
sf:LinkedFeature does not exist
Test wfs:GetFeatureWithLock-Xlink Passed
Testing wfs:wfs-1.1.0-GetFeatureWithLock-tc1.1 (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31884_1/d39e31274_1)...
Assertion:
report is returned.
Testing ctl:SchematronValidatingParser (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31884_1/d39e31274_1/d39e31471_1)...
Testing wfs:GetFeatureByName (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31884_1/d39e31274_1/d39e31508_1)...
Testing wfs:GetFeatureByName (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31884_1/d39e31274_1/d39e31576_1)...
Test wfs:wfs-1.1.0-GetFeatureWithLock-tc1.1 Passed
Testing wfs:wfs-1.1.0-GetFeatureWithLock-tc2.1 (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31884_1/d39e31287_1)...
Assertion:
If locks on all matching features cannot be acquired, the response to a
GetFeatureWithLock request must include an exception report.
Testing ctl:SchematronValidatingParser (wfs-1.1.0/d39e34902_1/d39e743_1/d39e31884_1/d39e31287_1/d39e31689_1)...
Test wfs:wfs-1.1.0-GetFeatureWithLock-tc2.1 Passed
Test wfs:run-GetFeatureWithLock-POST Passed
Test wfs:transaction-main Passed
Test wfs:readiness-tests Failed (Inherited failure)
Test wfs:wfs-main Failed (Inherited failure)
Suite ctl:wfs-1.1.0-compliance-suite Failed
Test wfs:wfs-main (wfs-1.1.0) Failed (Inherited Failure)
Test wfs:readiness-tests (wfs-1.1.0/d39e34902_1) Failed (Inherited Failure)
Test wfs:basic-main (wfs-1.1.0/d39e34902_1/d39e732_1) Failed (Inherited Failure)
Test wfs:run-GetFeature-POST (wfs-1.1.0/d39e34902_1/d39e732_1/d39e25206_1) Failed (Inherited Failure)
Test wfs:wfs-1.1.0-Basic-GetFeature-tc51.2 (wfs-1.1.0/d39e34902_1/d39e732_1/d39e25206_1/d39e16124_1) Failed
RETURN=1
Pinging GeoServer at http://localhost:11010/geoserver
curl: (7) couldn't connect to host
GeoServer is offline
