See <http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/282/>
[...truncated 973 lines...]
curl: (7) couldn't connect to host
Pinging GeoServer at http://localhost:11010/geoserver
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
GeoServer is online
Testing suite wms:main_wms...
Testing wms:main (wms-1.1.1)...
Assertion: This WMS is valid
Checking for <http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/wms-1.1.1.xml>
Testing wms:basic_elements-param_rules-order_and_case-3 (wms-1.1.1/d39e1374_1)...
Assertion: When a GetCapabilities request contains a parameter which is not defined by the spec, the result is valid.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&BoGuS=ignored&ReQuEsT=GetCapabilities&VeRsIoN=1.1.1; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$basic_elements-param_rules-order_and_case-3.test;> Line#: 52; Column#: -1
Test wms:basic_elements-param_rules-order_and_case-3 Failed
Testing wms:basic_elements-version-negotiation-2 (wms-1.1.1/d39e1412_1)...
Assertion: When a GetCapabilities request is made for a supported version, then the response is the requested version.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&ReQuEsT=GetCapabilities&VeRsIoN=1.1.1; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$basic_elements-version-negotiation-2.test;> Line#: 51; Column#: -1
Test wms:basic_elements-version-negotiation-2 Failed
Testing wms:basic_elements-version-negotiation-4 (wms-1.1.1/d39e1419_1)...
Assertion: When a GetCapabilities request is made for version 0.0.0, the response is between 0.0.0 and [[VAR_WMS_VERSION]], inclusive.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&VeRsIoN=0.0.0&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$basic_elements-version-negotiation-4.test;> Line#: 48; Column#: -1
Test wms:basic_elements-version-negotiation-4 Failed
Testing wms:dims-declaring-1 (wms-1.1.1/d39e1428_1)...
Assertion: No dimension name values in the capabilities document contain whitespace.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&VeRsIoN=1.1.1&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$dims-declaring-1.test;> Line#: 51; Column#: -1
Test wms:dims-declaring-1 Failed
Testing wms:dims-declaring-3 (wms-1.1.1/d39e1436_1)...
Assertion: All declarations for the time dimension use 'ISO8601' for units.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&ReQuEsT=GetCapabilities&VeRsIoN=1.1.1; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$dims-declaring-3.test;> Line#: 51; Column#: -1
Test wms:dims-declaring-3 Failed
Testing wms:dims-declaring-4 (wms-1.1.1/d39e1443_1)...
Assertion: All declarations for the elevation dimension use an EPSG vertical datum for units.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?ReQuEsT=GetCapabilities&VeRsIoN=1.1.1&SeRvIcE=WMS; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$dims-declaring-4.test;> Line#: 51; Column#: -1
Test wms:dims-declaring-4 Failed
Testing wms:profiles-queryable-1 (wms-1.1.1/d39e1473_1)...
Assertion: The server implements the CITE standard dataset in subsettable, resizable layers that support EPSG:4326.
Test wms:profiles-queryable-1 Failed
Testing wms:profiles-queryable-2 (wms-1.1.1/d39e1483_1)...
Assertion: The server supports GetMap format image/gif and/or image/png.
Test wms:profiles-queryable-2 Failed
Testing wms:profiles-queryable-3 (wms-1.1.1/d39e1493_1)...
Assertion: The server supports GetFeatureInfo requests and the CITE standard dataset layers containing polygons are queryable.
Test wms:profiles-queryable-3 Failed
Testing wms:wmsops-getcapabilities-output_formats-1 (wms-1.1.1/d39e1503_1)...
Assertion: The application/vnd.ogc.se_xml exception format is listed in the capabilities document.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?VeRsIoN=1.1.1&SeRvIcE=WMS&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-output_formats-1.test;> Line#: 51; Column#: -1
Test wms:wmsops-getcapabilities-output_formats-1 Failed
Testing wms:wmsops-getcapabilities-params-request-1 (wms-1.1.1/d39e1510_1)...
Assertion: When REQUEST is "capabilities", then the response is capabilities XML.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&ReQuEsT=capabilities&WmTvEr=1.1.1; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-params-request-1.test;> Line#: 48; Column#: -1
Test wms:wmsops-getcapabilities-params-request-1 Failed
Testing wms:wmsops-getcapabilities-params-updatesequence-1 (wms-1.1.1/d39e1520_1)...
Assertion: When a GetCapabilities request is made with an UPDATESEQUENCE parameter, then the UPDATESEQUENCE parameter is ignored.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?ReQuEsT=GetCapabilities&VeRsIoN=1.1.1&SeRvIcE=WMS&UpDaTeSeQuEnCe=ignored; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-params-updatesequence-1.test;> Line#: 52; Column#: -1
Test wms:wmsops-getcapabilities-params-updatesequence-1 Failed
Testing wms:wmsops-getcapabilities-params-version-1 (wms-1.1.1/d39e1589_1)...
Assertion: When a GetCapabilities request is made for the version in test using WMTVER instead of VERSION, then the response is the requested version.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&ReQuEsT=GetCapabilities&WmTvEr=1.1.1; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-params-version-1.test;> Line#: 51; Column#: -1
Test wms:wmsops-getcapabilities-params-version-1 Failed
Testing wms:wmsops-getcapabilities-params-version-2 (wms-1.1.1/d39e1596_1)...
Assertion: When a GetCapabilities request is made for a supported version other than [[VAR_WMS_VERSION]] using WMTVER instead of VERSION, then the version returned is the version requested.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?ReQuEsT=GetCapabilities&SeRvIcE=WMS&VeRsIoN=0.0.0; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-params-version-2.test;> Line#: 48; Column#: -1
Test wms:wmsops-getcapabilities-params-version-2 Failed
Testing wms:wmsops-getcapabilities-params-version-3 (wms-1.1.1/d39e1603_1)...
Assertion: When a GetCapabilities request is made with VERSION set to [[VAR_WMS_VERSION]] and WMTVER set to 0.0.0 and VERSION precedes WMTVER, then the version returned is [[VAR_WMS_VERSION]].
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: VERSION=1.1.1&?SeRvIcE=WMS&WmTvEr=0.0.0&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-params-version-3.test;> Line#: 48; Column#: -1
Test wms:wmsops-getcapabilities-params-version-3 Failed
Testing wms:wmsops-getcapabilities-params-version-4 (wms-1.1.1/d39e1610_1)...
Assertion: When a GetCapabilities request is made with VERSION set to [[VAR_WMS_VERSION]] and WMTVER set to 100.0.0 and VERSION precedes WMTVER, then the version returned is [[VAR_WMS_VERSION]].
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: VERSION=1.1.1&?WmTvEr=100.0.0&SeRvIcE=WMS&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-params-version-4.test;> Line#: 48; Column#: -1
Test wms:wmsops-getcapabilities-params-version-4 Failed
Testing wms:wmsops-getcapabilities-params-version-5 (wms-1.1.1/d39e1617_1)...
Assertion: When a GetCapabilities request is made with VERSION set to [[VAR_WMS_VERSION]] and WMTVER set to 0.0.0 and WMTVER precedes VERSION, then the version returned is [[VAR_WMS_VERSION]].
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: WMTVER=0.0.0&?SeRvIcE=WMS&VeRsIoN=1.1.1&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-params-version-5.test;> Line#: 50; Column#: -1
Test wms:wmsops-getcapabilities-params-version-5 Failed
Testing wms:wmsops-getcapabilities-params-version-6 (wms-1.1.1/d39e1624_1)...
Assertion: When a GetCapabilities request is made with VERSION set to [[VAR_WMS_VERSION]] and WMTVER set to 100.0.0 and WMTVER precedes VERSION, then the version returned is [[VAR_WMS_VERSION]].
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: WMTVER=100.0.0&?SeRvIcE=WMS&ReQuEsT=GetCapabilities&VeRsIoN=1.1.1; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-params-version-6.test;> Line#: 50; Column#: -1
Test wms:wmsops-getcapabilities-params-version-6 Failed
Testing wms:wmsops-getcapabilities-response-1 (wms-1.1.1/d39e1632_1)...
Assertion: When a GetCapabilities request is made, then the content-type header of the response is application/vnd.ogc.wms_xml
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&ReQuEsT=GetCapabilities&VeRsIoN=1.1.1; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-1.test;> Line#: 52; Column#: -1
Test wms:wmsops-getcapabilities-response-1 Failed
Testing wms:wmsops-getcapabilities-response-2 (wms-1.1.1/d39e1639_1)...
Assertion: The response to a GetCapabilities request references a valid copy of the DTD in Annex A.1 at a fully-quallified and accessible location and validates with the DTD.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?ReQuEsT=GetCapabilities&SeRvIcE=WMS&VeRsIoN=1.1.1; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-2.test;> Line#: 52; Column#: -1
Test wms:wmsops-getcapabilities-response-2 Failed
Testing wms:wmsops-getcapabilities-response-capability_metadata-1 (wms-1.1.1/d39e1646_1)...
Assertion: Each OnlineResource URL intended for HTTP Get requests in the capabilities document is a URL prefix
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&VeRsIoN=1.1.1&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-capability_metadata-1.test;> Line#: 51; Column#: -1
Test wms:wmsops-getcapabilities-response-capability_metadata-1 Failed
Testing wms:wmsops-getcapabilities-response-capability_metadata-2 (wms-1.1.1/d39e1655_1)...
Assertion: The output format application/vnd.ogc.gml is listed for the GetFeatureInfo operation.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?ReQuEsT=GetCapabilities&VeRsIoN=1.1.1&SeRvIcE=WMS; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-capability_metadata-2.test;> Line#: 51; Column#: -1
Test wms:wmsops-getcapabilities-response-capability_metadata-2 Failed
Testing wms:wmsops-getcapabilities-response-general_metadata-1 (wms-1.1.1/d39e1663_1)...
Assertion: The Service Name element in the capabilities document has the value "OGC:WMS".
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&ReQuEsT=GetCapabilities&VeRsIoN=1.1.1; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-general_metadata-1.test;> Line#: 51; Column#: -1
Test wms:wmsops-getcapabilities-response-general_metadata-1 Failed
Testing wms:wmsops-getcapabilities-response-general_metadata-2 (wms-1.1.1/d39e1672_1)...
Assertion: The word "none" (case-insensitive) is used in the content of the Fees element and the AccessConstraints element of the capabilities document.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?VeRsIoN=1.1.1&SeRvIcE=WMS&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-general_metadata-2.test;> Line#: 51; Column#: -1
Test wms:wmsops-getcapabilities-response-general_metadata-2 Failed
Testing wms:wmsops-getcapabilities-response-layer_properties-bbox-1 (wms-1.1.1/d39e1681_1)...
Assertion: For each of the layer elements in the capabilities document, each BoundingBox on the layer states a different SRS.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&VeRsIoN=1.1.1&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-layer_properties-bbox-1.test;> Line#: 51; Column#: -1
Test wms:wmsops-getcapabilities-response-layer_properties-bbox-1 Failed
Testing wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-1 (wms-1.1.1/d39e1688_1)...
Assertion: There are no child Dimension elements in the capabilities document that use a name attribute that is defined in a parent layer.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?VeRsIoN=1.1.1&ReQuEsT=GetCapabilities&SeRvIcE=WMS; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-layer_properties-dim_and_extent-1.test;> Line#: 52; Column#: -1
Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-1 Failed
Testing wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-2 (wms-1.1.1/d39e1695_1)...
Assertion: Each Extent element in the capabilities document uses a name that has been declared or inherited in a corresponding Dimension element.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?ReQuEsT=GetCapabilities&VeRsIoN=1.1.1&SeRvIcE=WMS; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-layer_properties-dim_and_extent-2.test;> Line#: 52; Column#: -1
Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-2 Failed
Testing wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-1 (wms-1.1.1/d39e1702_1)...
Assertion: There are no child Layer elements in the capabilities document that define an AuthorityURL with the same name attribute as one inherited from a parent layer.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?VeRsIoN=1.1.1&ReQuEsT=GetCapabilities&SeRvIcE=WMS; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-1.test;> Line#: 52; Column#: -1
Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-1 Failed
Testing wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-2 (wms-1.1.1/d39e1709_1)...
Assertion: There are no Layer elements in the capabilities document that declare an Identifier without also declaring or inheriting a corresponding AuthorityURL.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?VeRsIoN=1.1.1&SeRvIcE=WMS&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-2.test;> Line#: 52; Column#: -1
Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-2 Failed
Testing wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-1 (wms-1.1.1/d39e1716_1)...
Assertion: The root layer in the capabilities document has a LatLonBoundingBox.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?VeRsIoN=1.1.1&ReQuEsT=GetCapabilities&SeRvIcE=WMS; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-layer_properties-latlonbbox-1.test;> Line#: 52; Column#: -1
Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-1 Failed
Testing wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-2 (wms-1.1.1/d39e1724_1)...
Assertion: The minx, miny, maxx, and maxy attributes on each LatLonBoundingBox are expressed in decimal degrees.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?VeRsIoN=1.1.1&SeRvIcE=WMS&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-layer_properties-latlonbbox-2.test;> Line#: 52; Column#: -1
Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-2 Failed
Testing wms:wmsops-getcapabilities-response-layer_properties-srs-1 (wms-1.1.1/d39e1731_1)...
Assertion: The root layer in the capabilities document has at least one SRS element.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?ReQuEsT=GetCapabilities&VeRsIoN=1.1.1&SeRvIcE=WMS; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-layer_properties-srs-1.test;> Line#: 51; Column#: -1
Test wms:wmsops-getcapabilities-response-layer_properties-srs-1 Failed
Testing wms:wmsops-getcapabilities-response-layer_properties-style-1 (wms-1.1.1/d39e1738_1)...
Assertion: There are no child layers in the capabilities document that redefine a Style with the same name as one inherited from one of its parents.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SeRvIcE=WMS&VeRsIoN=1.1.1&ReQuEsT=GetCapabilities; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getcapabilities-response-layer_properties-style-1.test;> Line#: 51; Column#: -1
Test wms:wmsops-getcapabilities-response-layer_properties-style-1 Failed
Testing wms:wmsops-getmap-params-exceptions-1 (wms-1.1.1/d39e2149_1)...
Assertion: When an exception is raised without specifying the EXCEPTIONS parameter, then the Content-type of the return header is application/vnd.ogc.se_xml.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SrS=EPSG:4326&WiDtH=100&VeRsIoN=1.1.1&BbOx=-1,-1,1,1&LaYeRs=NonExistant&StYlEs=&HeIgHt=100&ReQuEsT=GetMap&FoRmAt=; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getmap-params-exceptions-1.test;> Line#: 65; Column#: -1
Test wms:wmsops-getmap-params-exceptions-1 Failed
Testing wms:wmsops-getmap-params-exceptions-2 (wms-1.1.1/d39e2158_1)...
Assertion: When an exception is raised and EXCEPTIONS=application/vnd.ogc.se_xml, then the Content-type of the return header is application/vnd.ogc.se_xml.
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?FoRmAt=&ReQuEsT=GetMap&VeRsIoN=1.1.1&StYlEs=&BbOx=-1,-1,1,1&WiDtH=100&ExCePtIoNs=application/vnd.ogc.se_xml&LaYeRs=NonExistant&SrS=EPSG:4326&HeIgHt=100; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getmap-params-exceptions-2.test;> Line#: 66; Column#: -1
Test wms:wmsops-getmap-params-exceptions-2 Failed
Testing wms:wmsops-getmap-params-layers-5 (wms-1.1.1/d39e2314_1)...
Assertion: When the layer in a GetMap request is invalid, then the response is an exception (code="LayerNotDefined").
Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SrS=EPSG:4326&LaYeRs=NonExistant&StYlEs=&ReQuEsT=GetMap&HeIgHt=96&FoRmAt=&VeRsIoN=1.1.1&BbOx=-0.0042,-0.0024,0.0042,0.0024&WiDtH=168; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getmap-params-layers-5.test;> Line#: 64; Column#: -1
Test wms:wmsops-getmap-params-layers-5 Failed
Testing wms:wmsops-getmap-layer-encoded-name (wms-1.1.1/d39e2739_1)...
Assertion: When a layer is requested using encoded characters in its name, the response is a map.
Fatal Error: Error invoking {http://www.occamlab.com/wms-1.1.1/src/ctl/functions.xml\}encode
java.lang.NullPointerException; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$wmsops-getmap-layer-encoded-name.test;> Line#: 28; Column#: -1
Test wms:wmsops-getmap-layer-encoded-name Failed
Testing wms:basic_elements-validate-exception (wms-1.1.1/d39e2745_1)...
Assertion: When an exception is generated, it validates.
java.lang.NullPointerException; SystemID: file://<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-trunk/ws/tools/target/work/~2Fhome~2Ftomcat~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwms-1.1.1~2Fctl~2Fwms.xml/wms$basic_elements-validate-exception.test;> Line#: 28; Column#: -1
Test wms:basic_elements-validate-exception Failed
Test wms:main Failed (Inherited failure)
Suite wms:main_wms Failed
Test wms:main (wms-1.1.1) Failed (Inherited Failure)
Test wms:basic_elements-param_rules-order_and_case-3 (wms-1.1.1/d39e1374_1) Failed
Test wms:basic_elements-version-negotiation-2 (wms-1.1.1/d39e1412_1) Failed
Test wms:basic_elements-version-negotiation-4 (wms-1.1.1/d39e1419_1) Failed
Test wms:dims-declaring-1 (wms-1.1.1/d39e1428_1) Failed
Test wms:dims-declaring-3 (wms-1.1.1/d39e1436_1) Failed
Test wms:dims-declaring-4 (wms-1.1.1/d39e1443_1) Failed
Test wms:profiles-queryable-1 (wms-1.1.1/d39e1473_1) Failed
Test wms:profiles-queryable-2 (wms-1.1.1/d39e1483_1) Failed
Test wms:profiles-queryable-3 (wms-1.1.1/d39e1493_1) Failed
Test wms:wmsops-getcapabilities-output_formats-1 (wms-1.1.1/d39e1503_1) Failed
Test wms:wmsops-getcapabilities-params-request-1 (wms-1.1.1/d39e1510_1) Failed
Test wms:wmsops-getcapabilities-params-updatesequence-1 (wms-1.1.1/d39e1520_1) Failed
Test wms:wmsops-getcapabilities-params-version-1 (wms-1.1.1/d39e1589_1) Failed
Test wms:wmsops-getcapabilities-params-version-2 (wms-1.1.1/d39e1596_1) Failed
Test wms:wmsops-getcapabilities-params-version-3 (wms-1.1.1/d39e1603_1) Failed
Test wms:wmsops-getcapabilities-params-version-4 (wms-1.1.1/d39e1610_1) Failed
Test wms:wmsops-getcapabilities-params-version-5 (wms-1.1.1/d39e1617_1) Failed
Test wms:wmsops-getcapabilities-params-version-6 (wms-1.1.1/d39e1624_1) Failed
Test wms:wmsops-getcapabilities-response-1 (wms-1.1.1/d39e1632_1) Failed
Test wms:wmsops-getcapabilities-response-2 (wms-1.1.1/d39e1639_1) Failed
Test wms:wmsops-getcapabilities-response-capability_metadata-1 (wms-1.1.1/d39e1646_1) Failed
Test wms:wmsops-getcapabilities-response-capability_metadata-2 (wms-1.1.1/d39e1655_1) Failed
Test wms:wmsops-getcapabilities-response-general_metadata-1 (wms-1.1.1/d39e1663_1) Failed
Test wms:wmsops-getcapabilities-response-general_metadata-2 (wms-1.1.1/d39e1672_1) Failed
Test wms:wmsops-getcapabilities-response-layer_properties-bbox-1 (wms-1.1.1/d39e1681_1) Failed
Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-1 (wms-1.1.1/d39e1688_1) Failed
Test wms:wmsops-getcapabilities-response-layer_properties-dim_and_extent-2 (wms-1.1.1/d39e1695_1) Failed
Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-1 (wms-1.1.1/d39e1702_1) Failed
Test wms:wmsops-getcapabilities-response-layer_properties-identifier_and_authorityurl-2 (wms-1.1.1/d39e1709_1) Failed
Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-1 (wms-1.1.1/d39e1716_1) Failed
Test wms:wmsops-getcapabilities-response-layer_properties-latlonbbox-2 (wms-1.1.1/d39e1724_1) Failed
Test wms:wmsops-getcapabilities-response-layer_properties-srs-1 (wms-1.1.1/d39e1731_1) Failed
Test wms:wmsops-getcapabilities-response-layer_properties-style-1 (wms-1.1.1/d39e1738_1) Failed
Test wms:wmsops-getmap-params-exceptions-1 (wms-1.1.1/d39e2149_1) Failed
Test wms:wmsops-getmap-params-exceptions-2 (wms-1.1.1/d39e2158_1) Failed
Test wms:wmsops-getmap-params-layers-5 (wms-1.1.1/d39e2314_1) Failed
Test wms:wmsops-getmap-layer-encoded-name (wms-1.1.1/d39e2739_1) Failed
Test wms:basic_elements-validate-exception (wms-1.1.1/d39e2745_1) Failed
RETURN=1
GeoServer is offline
