See <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/221/>
[...truncated 1577 lines...]
Test getmap:two-styles Passed
Testing getmap:three-styles (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4220_1)...
Assertion: When a GetMap request contains three valid layers and three valid styles (separated by commas), then the response is valid.
Test getmap:three-styles Passed
Testing getmap:invalid-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4222_1)...
Assertion: When a GetMap request contains an unadvertised Style, then the response is an exception (code=StyleNotDefined).
Test getmap:invalid-style Passed
Testing getmap:styles-default-single-layer (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4225_1)...
Assertion: When a GetMap request contains a single layer and a null style value (as in "STYLES="), then the response is valid.
Test getmap:styles-default-single-layer Passed
Testing getmap:styles-default-multiple-layers (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4227_1)...
Assertion: When a GetMap request contains multiple layers and requests all layers to be shown in the default style by using a single null value (as in "STYLES="), then the response is valid.
Test getmap:styles-default-multiple-layers Passed
Testing getmap:styles-default-commas (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4229_1)...
Assertion: When a GetMap request contains multiple layers and requests all layers to be shown in the default style by using null values between commas (as in "STYLES=,"), then the response is valid.
Test getmap:styles-default-commas Passed
Testing getmap:styles-some-default (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4231_1)...
Assertion: When a GetMap request contains multiple layers and a mixture of named and default styles (as in "STYLES=style1,style2,"), then the response is valid.
Test getmap:styles-some-default Passed
Testing getmap:first-style-invalid (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4233_1)...
Assertion: When a GetMap request contains two layers, where the first style is not valid and the second style is, then the response is an exception (code=StyleNotDefined).
Test getmap:first-style-invalid Passed
Testing getmap:second-style-invalid (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4235_1)...
Assertion: When a GetMap request contains two layers, where the first style is valid and the second style is not, then the response is an exception (code=StyleNotDefined).
Test getmap:second-style-invalid Passed
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_1)...
Assertion: For style "point", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Test getmap:each-style Passed
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_2)...
Assertion: For style "BasicPolygons", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_3)...
Assertion: For style "Bridges", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_4)...
Assertion: For style "Buildings", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_5)...
Assertion: For style "DividedRoutes", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_6)...
Assertion: For style "Forests", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_7)...
Assertion: For style "Lakes", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_8)...
Assertion: For style "polygon", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_9)...
Assertion: For style "MapNeatline", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_10)...
Assertion: For style "NamedPlaces", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_11)...
Assertion: For style "Ponds", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_12)...
Assertion: For style "RoadSegments", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Testing getmap:each-style (wms-1.3.0/d39e16863_1/d39e3979_1/d39e4242_13)...
Assertion: For style "Streams", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
Test getmap:styles Passed
Testing getmap:transparent (wms-1.3.0/d39e16863_1/d39e3981_1)...
Assertion: The TRANSPARENT parameter behaves properly.
Testing getmap:transparent-default (wms-1.3.0/d39e16863_1/d39e3981_1/d39e4264_1)...
Assertion: When a GetMap request is made with no TRANSPARENT parameter and a FORMAT that supports transparency over a layer that is not opaque, then the response contains no transparent pixels.
Test getmap:transparent-default Passed
Testing getmap:transparent-false (wms-1.3.0/d39e16863_1/d39e3981_1/d39e4266_1)...
Assertion: When a GetMap request is made with TRANSPARENT=FALSE and a FORMAT that supports transparency over a layer that is not opaque, then the response contains no transparent pixels.
Test getmap:transparent-false Passed
Testing getmap:transparent-true (wms-1.3.0/d39e16863_1/d39e3981_1/d39e4270_1)...
Assertion: When a GetMap request is made with TRANSPARENT=TRUE and a FORMAT that supports transparency over a BBOX that is not completely covered, then the response contains transparent pixels.
Test getmap:transparent-true Passed
Testing getmap:transparent-opaque-layer (wms-1.3.0/d39e16863_1/d39e3981_1/d39e4273_1)...
Assertion: Clients may request TRANSPARENT=TRUE on a layer that is opaque.
No named opaque layers.
Test getmap:transparent-opaque-layer Passed
Test getmap:transparent Passed
Testing getmap:width-and-height (wms-1.3.0/d39e16863_1/d39e3986_1)...
Assertion: The WIDTH and HEIGHT parameters behaves properly.
Testing getmap:large-size (wms-1.3.0/d39e16863_1/d39e3986_1/d39e4287_1)...
Assertion: When a request is made for a large map (1024x768 or largest map supported), the image returned is exactly the size requested.
Test getmap:large-size Passed
Testing getmap:small-size (wms-1.3.0/d39e16863_1/d39e3986_1/d39e4289_1)...
Assertion: When a request is made with WIDTH=8 and HEIGHT=5, the image returned is exactly the size requested.
Test getmap:small-size Passed
Test getmap:width-and-height Passed
Test getmap:main Failed (Inherited failure)
Testing getfeatureinfo:main (wms-1.3.0/d39e16870_1)...
Assertion: The GetFeatureInfo request behaves properly.
Testing getfeatureinfo:exceptions (wms-1.3.0/d39e16870_1/d39e10475_1)...
Assertion: The EXCEPTIONS parameter behaves properly.
Testing getfeatureinfo:exceptions-default (wms-1.3.0/d39e16870_1/d39e10475_1/d39e10519_1)...
Assertion: When an exception is raised and the EXCEPTIONS parameter is absent from the request, then the response is a valid exception with a Content-type header of text/xml.
Test getfeatureinfo:exceptions-default Passed
Testing getfeatureinfo:exceptions-xml (wms-1.3.0/d39e16870_1/d39e10475_1/d39e10521_1)...
Assertion: When an exception is raised and EXCEPTIONS=XML, then the response is a valid exception with a Content-type header of text/xml.
Test getfeatureinfo:exceptions-xml Passed
Test getfeatureinfo:exceptions Passed
Testing getfeatureinfo:feature_count (wms-1.3.0/d39e16870_1/d39e10492_1)...
Assertion: The FEATURE_COUNT parameter behaves properly.
Testing getfeatureinfo:feature_count-default (wms-1.3.0/d39e16870_1/d39e10492_1/d39e10539_1)...
Assertion: When the FEATURE_COUNT parameter is not specified, then less data is returned than when FEATURE_COUNT is 2.
Test getfeatureinfo:feature_count-default Passed
Testing getfeatureinfo:feature_count-1 (wms-1.3.0/d39e16870_1/d39e10492_1/d39e10541_1)...
Assertion: When the FEATURE_COUNT parameter is 1, then less data is returned than when FEATURE_COUNT is 2.
Test getfeatureinfo:feature_count-1 Passed
Test getfeatureinfo:feature_count Passed
Testing getfeatureinfo:info_format (wms-1.3.0/d39e16870_1/d39e10497_1)...
Assertion: The FORMAT parameter behaves properly.
Testing getfeatureinfo:invalid-info_format (wms-1.3.0/d39e16870_1/d39e10497_1/d39e10556_1)...
Assertion: When a GetFeatureInfo request is made with an invalid INFO_FORMAT parameter, then the server returns an exception (code=InvalidFormat).
Test getfeatureinfo:invalid-info_format Passed
Testing getfeatureinfo:each-info_format (wms-1.3.0/d39e16870_1/d39e10497_1/d39e10562_1)...
Assertion: For format "text/plain", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
Test getfeatureinfo:each-info_format Passed
Testing getfeatureinfo:each-info_format (wms-1.3.0/d39e16870_1/d39e10497_1/d39e10562_2)...
Assertion: For format "application/vnd.ogc.gml", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
Testing getfeatureinfo:each-info_format (wms-1.3.0/d39e16870_1/d39e10497_1/d39e10562_3)...
Assertion: For format "application/vnd.ogc.gml/3.1.1", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
Testing getfeatureinfo:each-info_format (wms-1.3.0/d39e16870_1/d39e10497_1/d39e10562_4)...
Assertion: For format "text/html", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
Test getfeatureinfo:info_format Passed
Testing getfeatureinfo:i-and-j (wms-1.3.0/d39e16870_1/d39e10499_1)...
Assertion: The I and J parameters behaves properly.
Testing getfeatureinfo:invalid-i (wms-1.3.0/d39e16870_1/d39e10499_1/d39e10582_1)...
Assertion: When a GetFeatureInfo request is made with an invalid I parameter, then the response is an exception (code=InvalidPoint).
Test getfeatureinfo:invalid-i Passed
Testing getfeatureinfo:invalid-j (wms-1.3.0/d39e16870_1/d39e10499_1/d39e10584_1)...
Assertion: When a GetFeatureInfo request is made with an invalid J parameter, then the response is an exception (code=InvalidPoint).
Test getfeatureinfo:invalid-j Passed
Test getfeatureinfo:i-and-j Passed
Testing getfeatureinfo:query-layers (wms-1.3.0/d39e16870_1/d39e10501_1)...
Assertion: The QUERY_LAYERS parameter behaves properly.
Testing getfeatureinfo:two-query_layers (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10599_1)...
Assertion: When a GetFeatureInfo request contains two layers, then the response is valid.
Test getfeatureinfo:two-query_layers Passed
Testing getfeatureinfo:three-query_layers (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10601_1)...
Assertion: When a GetFeatureInfo request contains three layers, then the response is valid.
Test getfeatureinfo:three-query_layers Passed
Testing getfeatureinfo:less-query_layers (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10603_1)...
Assertion: When a GetFeatureInfo request contains fewer layers in the QUERY_LAYERS parameter than it does in the LAYERS parameter, then the response is valid.
Test getfeatureinfo:less-query_layers Passed
Testing getfeatureinfo:invalid-query_layers (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10605_1)...
Assertion: When a layer requested is not contained in the Capabilities XML of the WMS, then the server issues a Service Exception (code=LayerNotDefined).
Test getfeatureinfo:invalid-query_layers Passed
Testing getfeatureinfo:query_layers-not-queryable (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10607_1)...
Assertion: When GetFeatureInfo is requested on a Layer that is not queryable, then the server issues a Service Exception (code=LayerNotQueryable).
No named layers that are not queryable.
Test getfeatureinfo:query_layers-not-queryable Passed
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_1)...
Assertion: For layer "cite:Autos", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Test getfeatureinfo:each-queryable-layer Passed
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_2)...
Assertion: For layer "cite:BasicPolygons", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_3)...
Assertion: For layer "cite:Bridges", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_4)...
Assertion: For layer "cite:BuildingCenters", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_5)...
Assertion: For layer "cite:Buildings", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_6)...
Assertion: For layer "cite:DividedRoutes", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_7)...
Assertion: For layer "cite:Forests", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_8)...
Assertion: For layer "cite:Lakes", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_9)...
Assertion: For layer "cite:LakesWithElevation", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_10)...
Assertion: For layer "cite:MapNeatline", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_11)...
Assertion: For layer "cite:NamedPlaces", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_12)...
Assertion: For layer "cite:Ponds", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_13)...
Assertion: For layer "cite:RoadSegments", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d39e16870_1/d39e10501_1/d39e10614_14)...
Assertion: For layer "cite:Streams", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
Test getfeatureinfo:query-layers Passed
Test getfeatureinfo:main Passed
Testing recomendations:main (wms-1.3.0/d39e16877_1)...
Assertion: If the "Check Recommendations" option was selected, the server supports fuctionality which is recommended in the spec, but not required.
Testing recomendations:service-keywords (wms-1.3.0/d39e16877_1/d39e12617_1)...
Assertion: The capabilities document includes a list of keywords or keyword phrases describing the server.
Test recomendations:service-keywords Passed
Testing recomendations:service-contact-info (wms-1.3.0/d39e16877_1/d39e12619_1)...
Assertion: The capabilities document includes contact information.
Test recomendations:service-contact-info Passed
Testing recomendations:png-getmap-format (wms-1.3.0/d39e16877_1/d39e12621_1)...
Assertion: The server advertises the image/png format for the GetMap operation.
Test recomendations:png-getmap-format Passed
Testing recomendations:layer-abstracts (wms-1.3.0/d39e16877_1/d39e12623_1)...
Assertion: Each Layer in the capabilities document contains an abstract.
Test recomendations:layer-abstracts Passed
Testing recomendations:layer-keywordlists (wms-1.3.0/d39e16877_1/d39e12625_1)...
Assertion: Each Layer in the capabilities document contains a keyword list.
Test recomendations:layer-keywordlists Passed
Testing recomendations:layer-crs (wms-1.3.0/d39e16877_1/d39e12628_1)...
Assertion: All layers in the capabilities document are available in the CRS:84 and/or EPSG:4326 CRS.
Test recomendations:layer-crs Passed
Testing recomendations:metadataurls (wms-1.3.0/d39e16877_1/d39e12630_1)...
Assertion: Every named Layer in the capabilities document contains a MetadataURL element.
Test recomendations:metadataurls Passed
Testing recomendations:dims-no-whitespace (wms-1.3.0/d39e16877_1/d39e12632_1)...
Assertion: No dimension name values in the capabilities document contain whitespace.
Test recomendations:dims-no-whitespace Passed
Testing recomendations:dims-defaults (wms-1.3.0/d39e16877_1/d39e12634_1)...
Assertion: Each dimension declaration in the capabilities document contains a default value.
Test recomendations:dims-defaults Passed
Test recomendations:main Passed
Testing dims:main (wms-1.3.0/d39e16880_1)...
Assertion: Support for dimensional data is correct.
Testing dims:missing-no-default (wms-1.3.0/d39e16880_1/d39e13057_1)...
Assertion: When a layer that has a dimension without a default value is requested without supplying the dimension parameter, the response is an exception with code=MissingDimensionValue.
No Named layers that have a dimension without a default value.
Test dims:missing-no-default Passed
Test dims:main Passed
Test main:main Failed (Inherited failure)
Suite wms-1.3.0:compliance_suite Failed
Test main:main (wms-1.3.0) Failed (Inherited Failure)
Test getmap:main (wms-1.3.0/d39e16863_1) Failed (Inherited Failure)
Test getmap:format (wms-1.3.0/d39e16863_1/d39e3971_1) Failed (Inherited Failure)
Test getmap:each-format (wms-1.3.0/d39e16863_1/d39e3971_1/d39e4139_4) Failed
Test getmap:each-format (wms-1.3.0/d39e16863_1/d39e3971_1/d39e4139_6) Failed
RETURN=1
Pinging GeoServer at http://localhost:11010/geoserver
curl: (7) couldn't connect to host
GeoServer is offline
