See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/113/changes
started
Updating https://svn.codehaus.org/geoserver/branches/1.6.x/geoserver
Fetching 'http://svn.codehaus.org/geoserver/trunk/configuration/minimal’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/community/community-schemas/web-c/minimal’
At revision 8622
Fetching 'http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/img’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/img’
At revision 6610
Fetching 'http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/lib’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/lib’
At revision 6610
Fetching 'http://svn.codehaus.org/geoserver/trunk/configuration/minimal’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/minimal’
At revision 8622
At revision 8622
no change for https://svn.codehaus.org/geoserver/branches/1.6.x/geoserver since the previous build
no change for http://svn.codehaus.org/geoserver/trunk/configuration/minimal since the previous build
no change for http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/img since the previous build
no change for http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/lib since the previous build
[geoserver] $ /opt/maven2/bin/mvn -U clean install -Djava.awt.headless=true
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer 1.6.x
[INFO] GeoServer Maven Plugins
[INFO] Plugins configuration files
[INFO] Configuration Deployment PlugIn
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Open Web Service Model
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Validation Module
[INFO] Web Feature Service Model
[INFO] Web Feature Service Module
[INFO] Versioning Web Feature Service Model
[INFO] Versioned Web Feature Service Module
[INFO] Web Map Service Module
[INFO] Web Application Module
[INFO] Test Module
[INFO] ----------------------------------------------------------------------------
[INFO] Building GeoServer 1.6.x
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from central
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from central
[INFO] artifact org.codehaus.mojo:cobertura-maven-plugin: checking for updates from refractions-plugins
[INFO] artifact org.codehaus.mojo:cobertura-maven-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-source-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-source-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/target
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from central
[INFO] [site:attach-descriptor]
[INFO] snapshot org.geotools:gt2-api:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-library:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-modules:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-referencing:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-metadata:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-main:2.4-SNAPSHOT: checking for updates from refractions
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/target/geoserver-1.6-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.6-SNAPSHOT/geoserver-1.6-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/target/geoserver-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.6-SNAPSHOT/geoserver-1.6-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target/maven-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.6-SNAPSHOT/maven-1.6-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target/maven-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.6-SNAPSHOT/maven-1.6-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from central
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6-SNAPSHOT/build-configs-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6-SNAPSHOT/build-configs-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6-SNAPSHOT/build-configs-1.6-SNAPSHOT-sources.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[ERROR] FATAL ERROR
[INFO] org.apache.maven.tools.plugin.scanner.MojoScanner.setActiveExtractors(Ljava/util/Set;)V
[INFO] Trace
java.lang.NoSuchMethodError: org.apache.maven.tools.plugin.scanner.MojoScanner.setActiveExtractors(Ljava/util/Set;)V
at org.apache.maven.plugin.plugin.AbstractGeneratorMojo.execute(AbstractGeneratorMojo.java:116)
at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:443)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:539)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:480)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:459)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:311)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:278)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:143)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:334)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:125)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:280)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
[INFO] Total time: 11 seconds
[INFO] Finished at: Wed Mar 26 08:30:06 EDT 2008
[INFO] Final Memory: 19M/36M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/114/changes
started
At revision 8622
At revision 6610
At revision 6610
At revision 8622
At revision 8622
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
[ERROR] FATAL ERROR
[INFO] Trace
[INFO] Finished at: Wed Mar 26 12:29:31 EDT 2008
[INFO] Final Memory: 19M/37M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/115/changes
Changes:
[groldan] GEOS-1815, fixed DescribeCoverage and WCS GetCapabilities to encode responses in the proper charset
[groldan] GEOS-1815, move OWS.getCharset() to Service (extends OWS) and make it explicitly delegate to GeoServer.getCharset()
started
U main/src/main/java/org/vfny/geoserver/global/Service.java
U main/src/main/java/org/vfny/geoserver/global/GeoServer.java
U wcs/src/main/java/org/vfny/geoserver/wcs/responses/DescribeResponse.java
U wcs/src/main/java/org/vfny/geoserver/wcs/responses/WCSCapabilitiesResponse.java
U wcs/src/main/java/org/vfny/geoserver/wcs/servlets/Describe.java
At revision 8624
At revision 6610
At revision 6610
At revision 8624
At revision 8624
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
[ERROR] FATAL ERROR
[INFO] Trace
[INFO] Total time: 14 seconds
[INFO] Finished at: Wed Mar 26 14:52:00 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/116/changes
Changes:
[groldan] GEOS-1815, remove get/setCharset from OWS
[groldan] GEOS-1815, set the encoding to the describeCoverage transformer
started
U ows/src/main/java/org/geoserver/ows/OWS.java
At revision 8627
At revision 6613
At revision 6613
At revision 8627
At revision 8627
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
[ERROR] FATAL ERROR
[INFO] Trace
[INFO] Total time: 12 seconds
[INFO] Finished at: Wed Mar 26 16:30:51 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/117/changes
Changes:
[groldan] GEOS-1815, respect character encoding for WMS xml responses
started
U community/kml-ows5/src/main/java/org/vfny/geoserver/wms/responses/map/kml/OWS5MapProducer.java
U wms/src/main/java/org/vfny/geoserver/wms/responses/WMSCapabilitiesResponse.java
U wms/src/main/java/org/vfny/geoserver/wms/responses/DescribeLayerResponse.java
U wms/src/main/java/org/vfny/geoserver/wms/responses/map/georss/AtomGeoRSSMapProducer.java
U wms/src/main/java/org/vfny/geoserver/wms/responses/map/georss/RSSGeoRSSMapProducer.java
U wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMZMapProducer.java
U wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLTransformer.java
U wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLMapProducer.java
U wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLReflector.java
At revision 8630
At revision 6613
At revision 6613
At revision 8630
At revision 8630
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
[ERROR] FATAL ERROR
[INFO] Trace
[INFO] Finished at: Wed Mar 26 17:21:08 EDT 2008
