[Geoserver-devel] Build failed in Hudson: geoserver-1.6.x #124
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/124/changes
Changes:
[groldan] GEOS-1830, fix double EPSG: prefix when limiting the list of crs's
[groldan] GEOS-1830, limit the list of exposes CRS identifiers through the WMS capabilities
[...truncated 1567 lines...]
3678/236K
3682/236K
3686/236K
3690/236K
3691/236K
3695/236K
3699/236K
3703/236K
3707/236K
3711/236K
3715/236K
3715/236K
3719/236K
3723/236K
3727/236K
3731/236K
3735/236K
3739/236K
3739/236K
3743/236K
3747/236K
3751/236K
3755/236K
3759/236K
3763/236K
3763/236K
3765/236K
3768/236K
3772/236K
3776/236K
3780/236K
3784/236K
3786/236K
3787/236K
3790/236K
3792/236K
3793/236K
3795/236K
3796/236K
3797/236K
3799/236K
3800/236K
3802/236K
3803/236K
3806/236K
3807/236K
3808/236K
3810/236K
3811/236K
3813/236K
3814/236K
3815/236K
3817/236K
3818/236K
3820/236K
3821/236K
3823/236K
3824/236K
3825/236K
3827/236K
3828/236K
3830/236K
3831/236K
3832/236K
3834/236K
3835/236K
3837/236K
3838/236K
3840/236K
3841/236K
3842/236K
3844/236K
3845/236K
3847/236K
3848/236K
3850/236K
236K downloaded
3851/152K
3853/152K
3855/152K
3858/152K
3861/152K
3864/152K
3868/152K
3872/152K
3876/152K
3878/152K
3881/152K
3884/152K
3888/152K
3892/152K
3896/152K
3900/152K
3902/152K
3905/152K
3906/152K
3910/152K
3913/152K
3915/152K
3919/152K
3923/152K
3923/152K
3927/152K
3927/152K
3930/152K
3932/152K
3935/152K
3939/152K
3943/152K
3943/152K
3946/152K
3950/152K
3953/152K
3956/152K
3957/152K
3959/152K
3961/152K
3963/152K
3964/152K
3966/152K
3968/152K
3971/152K
3975/152K
3978/152K
3981/152K
3983/152K
3985/152K
3989/152K
3990/152K
3991/152K
3993/152K
3994/152K
3998/152K
4002/152K
4003/152K
152K downloaded
4004/24K
4005/24K
4007/24K
4008/24K
4010/24K
4013/24K
4014/24K
4015/24K
4017/24K
4020/24K
4021/24K
4025/24K
4027/24K
24K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 16 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/classes
[INFO] [resources:testResources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 2 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.404 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Model
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target
[INFO] [resources:resources]
[INFO] Compiling 62 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/classes
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target
[INFO] Compiling 67 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/main/java/org/geoserver/ows/DefaultServiceExceptionHandler.java :[102,15] cannot find symbol
symbol : method setIndenting(boolean)
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/main/java/org/geoserver/ows/DefaultServiceExceptionHandler.java :[103,15] cannot find symbol
symbol : method setIndentSize(int)
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/main/java/org/geoserver/ows/DefaultServiceExceptionHandler.java :[104,15] cannot find symbol
symbol : method setLineWidth(int)
[INFO] Total time: 58 seconds
[INFO] Finished at: Fri Mar 28 14:52:38 EDT 2008
[INFO] Final Memory: 25M/45M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/125/changes
