See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/126/changes
Changes:
[bencaradocdavies] Re-enable community modules.
[...truncated 1591 lines...]
3668/342K
3671/342K
3672/342K
3676/342K
3679/342K
342K downloaded
3682/236K
3684/236K
3685/236K
3689/236K
3691/236K
3692/236K
3695/236K
3696/236K
3698/236K
3702/236K
3706/236K
3706/236K
3708/236K
3710/236K
3714/236K
3718/236K
3722/236K
3726/236K
3730/236K
3734/236K
3734/236K
3738/236K
3742/236K
3746/236K
3750/236K
3754/236K
3758/236K
3762/236K
3766/236K
3768/236K
3772/236K
3776/236K
3780/236K
3783/236K
3787/236K
3787/236K
3791/236K
3795/236K
3799/236K
3803/236K
3807/236K
3808/236K
3812/236K
3816/236K
3820/236K
3824/236K
3828/236K
3832/236K
3836/236K
3840/236K
3844/236K
3848/236K
3852/236K
3856/236K
3860/236K
3862/236K
3863/236K
3865/236K
3866/236K
3870/236K
3874/236K
3878/236K
3882/236K
3886/236K
3890/236K
3894/236K
3898/236K
3902/236K
3906/236K
3910/236K
3914/236K
3915/236K
236K downloaded
3917/152K
3918/152K
3921/152K
3923/152K
3924/152K
3927/152K
3928/152K
3930/152K
3931/152K
3932/152K
3936/152K
3940/152K
3944/152K
3948/152K
3952/152K
3955/152K
3956/152K
3958/152K
3962/152K
3966/152K
3970/152K
3974/152K
3976/152K
3978/152K
3979/152K
3981/152K
3985/152K
3989/152K
3992/152K
3993/152K
3995/152K
3996/152K
4000/152K
4003/152K
4005/152K
4009/152K
4013/152K
4014/152K
4017/152K
4019/152K
4020/152K
4022/152K
4024/152K
4027/152K
4030/152K
4031/152K
4035/152K
4038/152K
4040/152K
4044/152K
4044/152K
4048/152K
4052/152K
4056/152K
4060/152K
4064/152K
4065/152K
4067/152K
4068/152K
152K downloaded
4071/24K
4074/24K
4077/24K
4080/24K
4081/24K
4083/24K
4087/24K
4091/24K
4093/24K
24K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 16 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/classes
[INFO] [resources:testResources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 2 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.141 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Model
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target
[INFO] [resources:resources]
[INFO] Compiling 62 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/classes
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target
[INFO] Compiling 67 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/main/java/org/geoserver/ows/DefaultServiceExceptionHandler.java :[102,15] cannot find symbol
symbol : method setIndenting(boolean)
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/main/java/org/geoserver/ows/DefaultServiceExceptionHandler.java :[103,15] cannot find symbol
symbol : method setIndentSize(int)
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/main/java/org/geoserver/ows/DefaultServiceExceptionHandler.java :[104,15] cannot find symbol
symbol : method setLineWidth(int)
[INFO] Total time: 54 seconds
[INFO] Finished at: Sun Mar 30 22:52:31 EDT 2008
[INFO] Final Memory: 24M/48M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
