[Geoserver-devel] Build failed in Hudson: geoserver-1.6.x #145
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/145/changes
Changes:
[dwinslow] Make the version number for the rest module match geoserver.
[...truncated 255 lines...]
Results :
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6-SNAPSHOT/data-1.6-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Model
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 62 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6-SNAPSHOT/net.opengis.ows-1.6-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target
[INFO] Compiling 67 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/classes
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/surefire-reports
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.beans.factory.xml.XmlBeanDefinitionReader).
log4j:WARN Please initialize the log4j system properly.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.508 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
<ows:ExceptionReport version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns:ows="http://www.opengis.net/ows&quot;&gt;
  <ows:Exception exceptionCode="helloCode" locator="helloLocator">
    <ows:ExceptionText>hello service exception
helloText
I/O exception here
Illegal argument here</ows:ExceptionText>
    <ows:ExceptionText>helloText</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.448 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Results :
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/ows-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/ows-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/ows-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/ows-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.6-SNAPSHOT/ows-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/ows-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.6-SNAPSHOT/ows-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/ows-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.6-SNAPSHOT/ows-1.6-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target
[INFO] snapshot org.geotools:gt2-cql:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-validation:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-data:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-jdbc:2.4-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 121 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target/classes
[INFO] snapshot org.geoserver:data:1.6-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 5 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.468 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Apr 2, 2008 4:52:32 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: /tmp/test23352template
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.068 sec
Results :
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target/main-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target/main-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target/main-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target/main-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.6-SNAPSHOT/main-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target/main-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.6-SNAPSHOT/main-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/main/target/main-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.6-SNAPSHOT/main-1.6-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wcs/target
[INFO] snapshot org.geotools:gt2-arcgrid:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-geotiff:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-gtopo30:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-image:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-imagemosaic:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile:2.4-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 34 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wcs/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wcs/target/wcs-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wcs/target/wcs-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wcs/target/wcs-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wcs/target/wcs-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.6-SNAPSHOT/wcs-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wcs/target/wcs-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.6-SNAPSHOT/wcs-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wcs/target/wcs-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.6-SNAPSHOT/wcs-1.6-SNAPSHOT-sources.jar
[INFO] Building Validation Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/validation/target
[INFO] Compiling 6 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/validation/target/classes
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
  org.geotools:gt2-metadata:jar:2.4-SNAPSHOT
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  refractions (http://lists.refractions.net/m2/),
  mortbay (http://www.mortbay.org/maven2/release),
  geotools (http://maven.geotools.fr/repository/)
Path to dependency:
  1) org.geoserver:validation:jar:1.6-SNAPSHOT
  2) org.geoserver:main:jar:1.6-SNAPSHOT
  3) org.geotools:gt2-metadata:jar:2.4-SNAPSHOT
Caused by I/O exception: Connection refused
[INFO] Total time: 24 minutes 6 seconds
[INFO] Finished at: Wed Apr 02 17:15:43 EDT 2008
[INFO] Final Memory: 28M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/146/changes
