See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/158/changes
[...truncated 893 lines...]
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt2-render:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-render:2.4-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.4-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-wfs:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wfs:2.4-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-wms:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wms:2.4-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt2-xml:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml:2.4-SNAPSHOT: checking for updates from maven-restlet
[INFO] [compiler:compile]
[INFO] Compiling 129 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 19 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.432 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.224 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.716 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.192 sec
Running org.vfny.geoserver.wms.DescribeLayerTest
<WMS_DescribeLayerResponse version="1.1.1">
<LayerDescription name="cite:Forests" wfs="src/test/resources/geoserver/wfs/WfsDispatcher?">
<Query typeName="cite:Forests"/>
</LayerDescription>
</WMS_DescribeLayerResponse>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.397 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.372 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.4 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.248 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.848 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
org.vfny.geoserver.wms.WmsException: No such style: ThisStyleDoesNotExists
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.124 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<table border='1'>
<tr>
<th colspan='4' scope='col'>testType</th>
</tr>
<tr>
<td>string</td>
<td>int</td>
<td>double</td>
<td>geom</td>
</tr>
<tr>
<td>
three
</td>
<td>
3
</td>
<td>
3.3
</td>
<td>
[GEOMETRY]
</td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.416 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.564 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.728 sec
Results :
Tests run: 52, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.6-SNAPSHOT/wms-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.6-SNAPSHOT/wms-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.6-SNAPSHOT/wms-1.6-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] artifact org.geoserver.maven:config: checking for updates from mortbay-repo
[INFO] artifact org.geoserver.maven:config: checking for updates from refractions-plugins
[INFO] artifact org.geoserver.maven:config: checking for updates from central
[INFO] snapshot org.geoserver.maven:config:1.6-SNAPSHOT: checking for updates from mortbay-repo
[INFO] snapshot org.geoserver.maven:config:1.6-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geoserver.maven:config:1.6-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
[delete] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/src/main/webapp/data
[INFO] Compiling 108 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/classes
[INFO] Compiling 2 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/surefire-reports
T E S T S
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.725 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/web-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/web-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/web-1.6-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
[echo] Copying data dir from http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/minimal
[copy] Copying 14 files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/src/main/webapp/data
[copy] Copied 12 empty directories to 9 empty directories under http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/src/main/webapp/data
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/web-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.6-SNAPSHOT/web-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/web-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.6-SNAPSHOT/web-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/web-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.6-SNAPSHOT/web-1.6-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[1020 msecs]
[INFO] Building war: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/geoserver.war
[INFO] Building Test Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/test/target
[INFO] No sources to compile
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/test/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/test/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest
Apr 7, 2008 1:52:48 AM org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest testUserSpecifiedRule
INFO: testing single rule dirt_road from style Default Styler
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.44 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.kml.KMLWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.024 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.SVGMapProducerTest
Apr 7, 2008 1:52:48 AM org.geotools.map.DefaultMapContext setAreaOfInterest
INFO: USing a deprecated method!
Apr 7, 2008 1:52:48 AM org.vfny.geoserver.wms.responses.map.svg.EncodeSVG encode
INFO: SVG generated in 48 ms
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.184 sec
Running org.vfny.geoserver.wms.responses.GetMapResponseTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReaderTest
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/test/target/test-classes/org/vfny/geoserver/testdata/test-data
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.352 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.GIFMapProducerTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.048 sec <<< FAILURE!
Results :
Tests in error:
testUserSpecifiedRule(org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest)
testSimpleGetMapQuery(org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest)
testDefaultStyle(org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest)
testBlueLake(org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest)
testRemoteSLDMultipleStyles(org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReaderTest)
testSimpleGetMapQuery(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest)
testDefaultStyle(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest)
testBlueLake(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest)
Tests run: 15, Failures: 0, Errors: 8, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/test/target/surefire-reports for the individual test results.
[INFO] Total time: 3 minutes 14 seconds
[INFO] Finished at: Mon Apr 07 01:52:49 EDT 2008
[INFO] Final Memory: 31M/63M
