See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/16/changes
Changes:
[aaime] GEOS-1669 Exception reports by mistake n times the same message instead of using the messages got from the stack trace
[...truncated 56 lines...]
[INFO] Web Application Module
[INFO] Test Module
[INFO] ----------------------------------------------------------------------------
[INFO] Building GeoServer 1.6.x
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from central
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from central
[INFO] artifact org.codehaus.mojo:cobertura-maven-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/target
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from central
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/target/geoserver-1.6.0-RC2-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.6.0-RC2/geoserver-1.6.0-RC2.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/target/geoserver-1.6.0-RC2-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.6.0-RC2/geoserver-1.6.0-RC2-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target/maven-1.6.0-RC2-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.6.0-RC2/maven-1.6.0-RC2.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target/maven-1.6.0-RC2-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.6.0-RC2/maven-1.6.0-RC2-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from central
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt2-api:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-library:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-modules:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-referencing:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-metadata:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-main:2.4-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.0-RC2.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.0-RC2-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.0-RC2.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6.0-RC2/build-configs-1.6.0-RC2.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.0-RC2-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6.0-RC2/build-configs-1.6.0-RC2-tests.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6.0-RC2.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6.0-RC2-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6.0-RC2.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.6.0-RC2/config-1.6.0-RC2.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6.0-RC2-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.6.0-RC2/config-1.6.0-RC2-tests.jar
[INFO] [plugin:updateRegistry]
[INFO] Building Core Platform Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target
[INFO] Compiling 8 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6.0-RC2.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6.0-RC2-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6.0-RC2.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.6.0-RC2/platform-1.6.0-RC2.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6.0-RC2-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.6.0-RC2/platform-1.6.0-RC2-tests.jar
[INFO] Building Data Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target
[INFO] snapshot org.geotools.demo:gt2-demo-property:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo:2.4-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/classes
[INFO] Compiling 1 source file to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/surefire-reports
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6.0-RC2.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6.0-RC2-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6.0-RC2.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6.0-RC2/data-1.6.0-RC2.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/data-1.6.0-RC2-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.6.0-RC2/data-1.6.0-RC2-tests.jar
[INFO] Building Open Web Service Model
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target
[INFO] Compiling 62 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6.0-RC2.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6.0-RC2-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6.0-RC2.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6.0-RC2/net.opengis.ows-1.6.0-RC2.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.6.0-RC2-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.6.0-RC2/net.opengis.ows-1.6.0-RC2-tests.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target
[INFO] snapshot org.geotools:gt2-xml-xsd:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-unsupported:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-graph:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-extension:2.4-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 65 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/classes
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/target/test-classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/test/java/org/geoserver/ows/DefaultServiceExceptionHandlerTest.java :[15,24] package org.apache.xpath does not exist
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/ows/src/test/java/org/geoserver/ows/DefaultServiceExceptionHandlerTest.java :[94,29] cannot find symbol
symbol : variable XPathAPI
location: class org.geoserver.ows.DefaultServiceExceptionHandlerTest
[INFO] Total time: 28 seconds
[INFO] Finished at: Tue Jan 15 10:46:42 EST 2008
[INFO] Final Memory: 22M/43M
Updating GEOS-1669
