See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/190/changes
Changes:
[groldan] GEOS-1655, base url is either the proxy base or the local server base, not a mixin
[groldan] avoid NPE if there's no service keywords
[groldan] GEOS-1655, do not set proxyfied url in openlayers output, not our job, but the reverse proxy one
[groldan] just some javadocs pending of being commited
[groldan] GEOS-1655, get rid of proxyBaseUrl in web ui
[...truncated 878 lines...]
[INFO] Building Web Map Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt2-render:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wfs:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wms:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml:2.4-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 129 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 25 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.map.gif.GifMapProducerTest
Apr 25, 2008 12:53:35 PM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
25 Apr 12:53:35 ERROR [geotools.rendering] -
java.lang.NullPointerException
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1536)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:649)
at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1443)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1313)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:262)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:310)
at org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest.testSimpleGetMapQuery(DefaultRasterMapProducerTest.java:119)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:22)
at junit.extensions.TestSetup$1.protect(TestSetup.java:19)
at junit.extensions.TestSetup.run(TestSetup.java:23)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Apr 25, 2008 12:53:35 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testSimpleGetMapQuery: pixel count=90000 non bg pixels: 90000
INFO: testDefaultStyle Streams: pixel count=192000 non bg pixels: 3777
INFO: testDefaultStyle Bridges: pixel count=192000 non bg pixels: 49
Apr 25, 2008 12:53:36 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testDefaultStyle BasicPolygons: pixel count=280000 non bg pixels: 101880
INFO: testDefaultStyle Forests: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle NamedPlaces: pixel count=280000 non bg pixels: 56
INFO: testDefaultStyle Buildings: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle RoadSegments: pixel count=280000 non bg pixels: 63
INFO: testDefaultStyle DividedRoutes: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle Lakes: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle MapNeatline: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle Ponds: pixel count=280000 non bg pixels: 49
Apr 25, 2008 12:53:37 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testBlueLake: pixel count=250000 non bg pixels: 250000
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.184 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.42 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.508 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.328 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.316 sec
Running org.vfny.geoserver.wms.DescribeLayerTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.276 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Running org.geoserver.wms.CapabilitiesTest
Apr 25, 2008 12:53:39 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.712 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.328 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.86 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.348 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Apr 25, 2008 12:53:41 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.352 sec
Running org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest
Apr 25, 2008 12:53:42 PM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
25 Apr 12:53:42 ERROR [geotools.rendering] -
Apr 25, 2008 12:53:42 PM org.geoserver.wms.WMSTestSupport assertNotBlank
Apr 25, 2008 12:53:43 PM org.geoserver.wms.WMSTestSupport assertNotBlank
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.188 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.524 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
org.vfny.geoserver.wms.WmsException: No such style: ThisStyleDoesNotExists
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.444 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<table border='1'>
<tr>
<th colspan='2' scope='col'>testType</th>
</tr>
<tr>
<td>string</td> <td> three </td>
</tr>
<tr>
<td>int</td> <td> 3 </td>
</tr>
<tr>
<td>double</td> <td> 3.3 </td>
</tr>
<tr>
<td>geom</td> <td> [GEOMETRY] </td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Results :
Tests in error:
testDescribeLayerVersion111(org.vfny.geoserver.wms.DescribeLayerTest)
testDescribeLayerVersion110(org.vfny.geoserver.wms.DescribeLayerTest)
Tests run: 66, Failures: 0, Errors: 2, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 7 seconds
[INFO] Finished at: Fri Apr 25 12:53:46 EDT 2008
[INFO] Final Memory: 32M/63M
